- Ferrari is still running with the pull road suspension, but they focused on fine tuning and worked on the aerodynamic site
An der Vorderachse hält Ferrari stur an der Pullrod-Technik fest. In diesem Jahr wieder als einziges Team. Das Fahrwerk wurde vorne aber verfeinert und besser auf die Aerodynamik abgestimmt. Erstmals sind die Bremszangen unten angebracht.
Zusammen mit einem unteren Dreieckslenker, der sich nach Mercedes-Vorbild erst kurz vor dem Chassis spreizt, ergibt das einen tiefen Schwerpunkt und eine deutlich bessere Strömung hinter der Vorderachse. Weil sich der Anlenkpunkt der Zugstange jetzt hinter dem unteren Dreieckslenker versteckt.
"We think, just before the garage doors shut on the Sauber Ferrari...we caught a glimpse of a strange looking box at the back of the car above the gearbox...it could be to do with improving the throttle response of the car. We won't say too much more until we know exactly what that is, and we think we know exactly what that is."Morteza wrote:https://www.youtube.com/watch?v=5Ps_VfY7mrE
We should also take note that the ferrari engine is much smaller than the mercedes.Look on the shoulders behind the intakes..viperx wrote:Well if you have a look at this picture you can see that Ferrari's sidepods/rear end packaging is at least on par with Mercedes if not even betterSilent Storm wrote:- smallest sidepoids in the field.
I didn't understand this?? SF15-T does not have the smallest sidepod.
http://img3.auto-motor-und-sport.de/Fer ... 843458.jpg
Exactly, benefits of running high suspension were too good for them to abandon it. And frankly they still are, even tho suspension moved down in last years, it's still quite high compared to something in gp2. Still not as high as in F1 2013 season, when everyone still ran high suspension setups. High noses, that allowed funneling masses of air under them, offered too big aero advantage to offset penalty caused by higher center of gravity. But in 2014 merc, rb, mclaren and nearly everyone else, including Catherham with pullrods(!), moved into lower setups. I really found it curious to see Ferrari, that in 2013 had one of the highest noses and suspension setups, stay at the same point in 2014. I assumed that it must be caused by familiarity with pullrods, but it could also come from miscalculation in predicting what new noses will allow, or from a number of other reasons. I really never stumbled on official reason given for retaining same setup, nor of a well written analysis, so I'd be interested if one exists.ME4ME wrote:Don't be fooled though. Every config has it's advantages as well as disadvantages. It's a very interesting video, but only presents the advantages of the 2015 configuration while not even mentioning the disadvantages. My knowledge on suspension is very limited, but i'd imagine the suspension must be stiffened when ran under a lower angle leading to a heavier configuration. Ferrari has not won in a long time, but they are no fools.
Fuel use would be the same; 100kg/h. Because of that, power should stay close to constant as revs build and assuming the AFR doesn't richen to help lower exhaust temperatures. However; if power is holding steady across the 10,500 to 15,000 RPM range, torque would be linearly decreasing across the same band.Juzh wrote:High revs and less fuel consumption don't mix. I believe he was told the opposite. Higher gears for lower revs.ParkerArt wrote:Wouldn't torque also fall off as revs rise with this fuel limit? I thought I remember a radio message to Rosberg in one of the earlier races to use lower gears with higher revs to help with tire management and corner exit oversteer.Juzh wrote:
But because 100kg/h => higher revs => same fuel => same air => more friction => less power.
So 2015 has lower front roll center than 2014. All else being equal, this leads to less lateral load transfer at front. Therefore more total grip at front. It's roughly analogous to a softer front anti-roll-bar.stefan_ wrote:https://www.youtube.com/watch?v=EQzMrbDtndE
Fuel use would be the same after 10500, yes. That's why he was told to use higher gears, so he's below 10.5k for more of the time.ParkerArt wrote: Fuel use would be the same; 100kg/h. Because of that, power should stay close to constant as revs build and assuming the AFR doesn't richen to help lower exhaust temperatures. However; if power is holding steady across the 10,500 to 15,000 RPM range, torque would be linearly decreasing across the same band.
I do know know whether the lower torque of over-revving a lower gear would offset the addition mechanical torque multiplication of being in a lower gear though.
I may be wrong, but judging by the size of the swelling, I'd say they have playing around with the cooling that was formerly related to the now extinct 'ears', but that's for another thread.ringo wrote:We should also take note that the ferrari engine is much smaller than the mercedes.Look on the shoulders behind the intakes..
You can see that mercedes has it's new hump, which may be the variable intake runners. It seems ferarri have decided not to implement those. Or we could possibly see them in this weeks test. maybe they will compare both solutions.
Something tells me that this year mercedes wont have its way.
Could it also for example be like:Juzh wrote:Fuel use would be the same after 10500, yes. That's why he was told to use higher gears, so he's below 10.5k for more of the time.ParkerArt wrote: Fuel use would be the same; 100kg/h. Because of that, power should stay close to constant as revs build and assuming the AFR doesn't richen to help lower exhaust temperatures. However; if power is holding steady across the 10,500 to 15,000 RPM range, torque would be linearly decreasing across the same band.
Why would you do that? You'd be just leaving things on the table that way.George-Jung wrote:Could it also for example be like:
13500 rpm = 100kg/h
12500 rpm = 95kg/h
11500 rpm = 90kg/h
10500 rpm = 85kg/h
etc..
In this situation you still have more power at higher revs right?
