McLaren MCL32 Honda
Jef Patat
Jef Patat
Re: McLaren MCL32 Honda
There might be something going on there with the cooling. One side has the gill, the other side is completely open.
The side with the aero rake is open? That must have an influence I would think.
kalinka
kalinka
Goran2812 wrote:they've cut out cooling outlets that weren't there in the beginning... cooling problems because of too tight packaging?
Not necessary. Using flowiz that's spread downstream of the outlet suggest they are evaluating outlet's impact on airflow above the sidepod. Probably they will go trough all types of outlets that's developed to be placed there regardless of engine cooling.
hemichromis
hemichromis
Jef Patat wrote:There might be something going on there with the cooling. One side has the gill, the other side is completely open.
https://pbs.twimg.com/media/C50iHCPWgAMCcpO.jpg:large
This car is starting to look really quite beautiful!
Some Pictures by AMuS:
You've seen nothing....
FW Detail
Brake Assembly
Jef Patat
Jef Patat
First one is not MCL32
RedNEO
40
RedNEO
40
RedNEO
40
jagunx51
185
2 holes (?)
S-duct inlet ..... and ??
Xero
32
jagunx51 wrote:2 holes (?)
http://i1376.photobucket.com/albums/ah3 ... at7iz8.jpg
Driver cooling I'd imagine.
DiogoBrand
74
Looks too big to be just for driver cooling, I imagine.
Edit:
Those are probably the best looking cascades I've ever seen. Hopefully they work well.
GoranF1
GoranF1
151
Chasiss not perfect either car sliding alot.
https://twitter.com/publogic/status/836947247115952129
proteus
22
In this video there are more corners where Mclaren is seen.
https://www.youtube.com/watch?v=VVZ-oK95Sn0
HPD
198
