Mercedes GP W02
ESPImperium
ESPImperium
64
Re: Mercedes GP W02
Mercedes have developed the best of all the feild so far is the DRS as their DRS seems to do its job better than any in the feild, as they have solved the problem they had early season with flow re-attachement.
Reason: Removed OT and moved it to the Renault thread.
Ferraripilot
21
Re: Mercedes GP W02
New floors with EBD coming for Silverstone per Brawn at a press conf this afternoon.
240
Re: Mercedes GP W02
It actually suffers with the radiator arrangement, the tyre wear, the cooling, the aero, almost everything it suffers all because of the lack of space.
They should put a 4 inch spacer/adapter between the gearbox and engine.
They've thrown everything and the kitchen sink. Might as well put in the spacer and ease the other burdens by redesigning the cooling, the exhaust, the floors and sidepods.
Reason: removed OT
Giblet
Giblet
Re: Mercedes GP W02
Really, developments of the car please. Stop bickering about other cars and wheelbases.
If you have to talk about the team do it in the Mercedes GP 2011 thread.
hardingfv32
hardingfv32
Re: Mercedes GP W02
How do you propose getting a sufficient amount of air flow to the wing slot? Not just any air source but one that has a passive activation characteristic.
Brian
GSBellew
GSBellew
Re: Mercedes GP W02
The Monaco spec gills on the side pod above the exhaust outlet were back again in practice 3 so no solution to the cooling issues yet :(
Re: Mercedes GP W02
Mercedes is chipping away at their issues ,or how it is called by MS :work in progress.
Instead of overambitious throwing of updates they work with what they got and know and use FP1/2 to test /map possible development steps for the next races without losing the plot and sacrifice setup quality in the face of changing regs this seems a reasonable attitude.
Calm and collected focused on the big target...as they should be .
Adamski
Re: Mercedes GP W02
ringo wrote:It actually suffers with the radiator arrangement, the tyre wear, the cooling, the aero, almost everything it suffers all because of the lack of space.
I fully apply your opinions Ringo, as it's now confirmed that they miscalculated (again) the wheelbase and the balance of the car.
But why they are don't do what you say? I think it's the rules of homologation, as they can't change the chassis, isn't it?
Michael Schumacher: When you start out in a team, you have to get the teamwork going and then you get something back.
Re: Mercedes GP W02
nah.
a spacer will seriously compromise the installation stiffness then you need new floor and to make use of the found space a reshaped sidepod would be needed as well...
But are theay really wrong with what they got? it´s not like they struggle to get into Q3 now they understand the car ..They are fighting with renault for p4 in the constructors so relative to the opposition they have made similar progress methinks.
Adamski
Re: Mercedes GP W02
marcush. wrote:nah.
It was Ross Brawn, who says if they can start today rebuilding this car, they do some things ("The wheel base perhaps, the fuel weight, the fuel distribution") in a different way.
So I think if the rules would enabled some bigger changes on the car, they would probably did it.
Joie de vivre
Re: Mercedes GP W02
i dont get it
why the hell arent they using new updates??? they are a second slower than first one
Re: Mercedes GP W02
Brawn said they would have done thin gs differently .Hindsight is a great thing but not necesaryly it is indicating you would NOW change everything if you could.
They learn a whole lot these days.
You learn most from the things you do wrong not from what you do right but don´t know why.
vealio
vealio
Re: Mercedes GP W02
He said the position of the fuel cell could be better (CoG too high), wheelbase too so basically the same things as last year. Wonder why they got it wrong again for the W02 when they knew the W01 had those issues and it was the wrong way to go?
Re: Mercedes GP W02
Too conservative designers. You those people who are afraid to throw all their previous work into the trash (or recycle bin?)? I have a feeling that those are the guys at Merc. Too conservative - afraid to change big.
Adamski
Re: Mercedes GP W02
n smikle wrote:Too conservative designers. You those people who are afraid to throw all their previous work into the trash (or recycle bin?)? I have a feeling that those are the guys at Merc. Too conservative - afraid to change big.
If it's not a big change, than what?
