dialtone
dialtone
123
29 Oct 2023, 00:14
Seems Ferrari were quicker on one lap. With such a long straight and slow corners, it shouldn't be too surprising. Hopefully the investigation won't lead to a penalty; if it does, a win would be very tricky
No way, Max will win even starting 10th+. It would be nice to get a double podium though for Ferrari.
dialtone wrote:
29 Oct 2023, 00:24
29 Oct 2023, 00:14
At Mexico?! I don't think it's easy to pass and keep the brakes, tyres and engine temps under control
Marko verdict on quali
"They made full use of the engine's power, but I don't think they can maintain that over the full race distance. It has to be that way, because we have no other explanation for it. If you look at their training results, they have to have been bluffing until Q3," says Red Bull's motorsport consultant.
Marko believes Verstappen underperformed in Q3 and should be quicker than the Ferraris in race trim. He says: "Max didn't have a clean lap in turn 13/14, in the last sector. Not in both runs. That cost him around one and a half tenths of a second in each case."
Marko praises Ricciardo: "The other surprise is Ricciardo, very positive for us."
Juzh
161
At some point when you consistently can't get "clean 13/14" you just have to accept that's what the car is capable off. I've looked at his fast laps and none of them would suggest something was seriously off in Q3 in that section. Relying on perfect laps week in week out to achieve pole position won't get you there on a regular basis.
In any case (penalty or not) we'll have race tomorrow. Marko is saying ferrari engine is strong, as we all know, however looking at speed traces RB is nearly a match for them, so if there's pace in the car then Max will be able to overtake.
This is why Honda need to intervene on the PU. The Ferrari PU is just ridiculous. You can see it in the telemetry. The velocity line is steeper.
Xyz22
Xyz22
124
Juzh wrote:
29 Oct 2023, 01:18
It's the usual Marko post quali comment. He always finds something if Max isn't on pole.
Moreover, Max will win easily tomorrow.
Juzh
161
29 Oct 2023, 01:19
You sure you got that right? I'm looking at f1 tempo and Ver and Per are dare I say faster on straights, but lose out in slow corners T2-3-4 and then again in the following section.
djos
113
Wow! What a qually session!
If Daniel beating Perez in every qually session doesn’t prove to RedBull that he deserves the 2nd RedBull seat, I don’t know what does!
"In downforce we trust"
Juzh wrote:
29 Oct 2023, 01:25
29 Oct 2023, 01:19
Okay maybe I'm interpreting that incorrectly. Isn't the RB supposed to be the more efficient car? ferrari's pace really came from nowhere. Marko suggested it was PU.
DoctorRadio
DoctorRadio
Juzh wrote:
29 Oct 2023, 01:25
29 Oct 2023, 01:19
I had a look at lap 16 of Leclerc, his second Q3 run, he was faster on the straights than the first run and faster than the Red Bulls, suggesting it’s where they went really at full power.
It wasn’t absolutely a big difference on the straights between Ferrari and Red Bull, but taking into account that Ferrari should have more drag, Marko’s quotes (that they used full power) make sense.
djos
113
29 Oct 2023, 01:57
Juzh wrote:
29 Oct 2023, 01:25
29 Oct 2023, 01:19
The track temp dropped by 4 degrees at the start of Q3 and the Ferraris came alive. In Q2 they were sliding out of the last turn, in that first Q3 run they looked like they were on rails.
I doubt PU had anything to do with it.
dialtone
dialtone
123
djos wrote:
29 Oct 2023, 02:04
29 Oct 2023, 01:57
Juzh wrote:
29 Oct 2023, 01:25
In Q2 Ferrari had a first attempt on used tyres and a second attempt barely 0.2s off with a smidge of oversteer on exit which was still there in Q3, just a bit less but hardly responsible for 0.2s. In Q1 they went through with 3rd place with a time on mediums that also was about 0.2s off Max. The car is good here on a single lap, with some luck LEC can get 2nd tomorrow.
djos
113
If you are getting oversteer for say 2/3rds of the lap, that could easily account for 2/10ths total. Going sideways is less efficient than going forwards.
dialtone
dialtone
123
djos wrote:
29 Oct 2023, 03:04
I just looked at LEC's Q2 attempt and he mostly has understeer in S1 and a blip of oversteer in the last corner. That's about it.
djos
113
dialtone wrote:
29 Oct 2023, 03:12
djos wrote:
29 Oct 2023, 03:04
Front tires sliding is just as bad the rear tires sliding. It’s just slower.
Regardless, his first Q3 lap was pretty much perfect, with no undesirable front or rear sliding. The reduced track temps clearly suited the Ferrari setup better.
