2026 Hybrid Powerunits
Re: 2026 Hybrid Powerunits
Badger wrote:
22 May 2026, 15:44
diffuser wrote:
22 May 2026, 15:30
You're blaming Audi cause they were the only ones to comment, when there is only 2 votes in favour of a 2027 change? The argument that the 2 in favour of the chnage for 2027 is a move to Minimize ADOU sounds about right.
I specifically mention Audi because they have been a core part of why these regs turned out the way they did. From F1 trying too swoon them to join with the power split, to them demanding things like the removal of the MGU-H, to then claiming they never insisted on the 50/50 split recently, but now opposing a change because of "cost" despite the cost being small in the context of F1 and tiny in the context of a major auto-manufacturer. They've added nothing to the product so far but caused a bunch of problems as far as I'm concerned.
The only manufacturer I can understand would be hesitant to switch for 2027 is Honda, just because they have a lot on their plate with how poorly that project is being managed.
Stop that, the others agreed. It was a negotiation between the manufactures, FOM and FIA. They all contributed to the current regs. The FIA added the CR limit, removed the MGU-H (they could have just standardized it and given it to a 3ird party to manufacture), Merc was against front brake regen.
EDIT
You're also, kind of, making mzos point that these regs have thier politics and it might take longer than expected to happen.
mzso
mzso
75
So, Russel is in favor of not touching the PU regs. And I think he's right in that the way they work now is what results in the on track action we have. If they take most of it away, well likely be back to a lot of following with little to no overtakes.
FW17
189
What happened to ADEO?
Who are the engine manufacturers allowed more updates this year?
Jaisonas
Jaisonas
Somehow the energy drinks company built the best ice although, not sure about the decision to measure only the ice for aduo and not the electric side of things considering it amounts to 50% of power.
https://www.the-race.com/formula-1/f1-e ... -revealed/
Cold Fussion
Cold Fussion
96
Would be interesting to know how they are measure it, and whether or not that now that the teams know the difference , whether or not the system is safe from being gamed because presumably now the teams will be able to work out how that difference was calculated.
venkyhere
45
Measuring only the ICE output to determine which is the 'benchmark PU' ignoring the MGU-K, the charge/discharge HW/SW - that's like a football referee deciding whether it was a foul or not based on how the crowd reacted rather than watching a replay. Once again, Reichmarshall Wolff and his team have 'gamed the system' by 'helping the FIA' frame the rules, test/measurement criteria etc.
LM10
LM10
127
Giving the manufacturer with the best PU by a big margin even more resources to develop it. Welcome to F1. :lol:
The fact that Mercedes' ICE is weak enough to be granted ADUO is really hard to believe to be honest. Or is this without the CR trick?
Sempre Forza Ferrari
gearboxtrouble
gearboxtrouble
LM10 wrote:
07 Jun 2026, 21:31
The CR rule change is the one thing I can see creating a 2% gap between RBPT and Mercedes. If an engine and fuel has been designed and optimized to operate above 16:1 and then been nerfed via a timing change to operate less efficiently to pass the new test then I could see a decently sized hp loss. Barcelona will be interesting - Max will get a new engine for the first time this season and the new CR test will be in place. If Mercedes is suddenly losing gobs of time on the straights that'll be a good indicator for what actually happened.
nico5
25
LM10 wrote:
07 Jun 2026, 21:31
Blue delta lines seem to go up in the straights, but maybe Tombazis is wearing his glasses upside down
FNTC
FNTC
The problem with ADUO is it is measuring ICE power only. So if the Mercedes ICE is 2% weaker than the RB one, they must have a better electrical half of the PU. MGU-K, battery, deployment, etc.
michl420
michl420
ICE is the only thing that brings power. MGUK and Batterie only manage what the ICE deliver and are exactly limited.
Badger
Badger
46
FNTC wrote:
08 Jun 2026, 00:22
I’m skeptical. All the energy you harvest ultimately comes from the ICE. The fact that Mercedes has the best on track engine performance is a very strong indicator that they also have the best ICE, hence why everyone in the paddock has been praising their engine all season. The ADUO decision speaks to a deeply flawed measurement process, gaming the system, corruption, or maybe all of the above.
Cold Fussion
Cold Fussion
96
The fact it is so opaque suggests at least it is easy to game.
Hoffman900
Hoffman900
243
Furthermore, we even haven’t seen the full reliability. All the teams could make a bunch more power if they wanted to replace engines at a regular clip (with penalty).
Who knows, RB might have the whick turned up just to keep up.
Peak power and the power band are not the same thing. It is like the difference between the Renault V8 and Mercedes V8 in 2010-2014. If one car sacrifice peak power in order to gain a power band that suits partial throttle and superclipping harvesting, then they can charge the battery better, while having less peak power output. What have the FIA done to account for this?
The ICE measurements will also fail to take into account exhaust flow restrictions induced by the flick tail mode. Ferrari sacrificed some horsepower when they put a cap over half of the exhaust pipe, and they also sacrified some power when they used the minimum cross section tail pipe in order to speed up the exhaust air flow for the flick tail mode. Higher velocity flow inside tailpipe generates higher flow losses. None of this can be measured by the torque meters.
I don't understand how it would have been possible for the FIA to take into account these basic concepts, and without taking this into account the results of the ADUO can be distorted.
Furthermore, even though the hybrid side produces no energy (its coming from the fuel), that does not mean the hybrid side does not CONSUME energy. The hybrid system is not 100% efficient. There is irreversible loss of energy inside the battery due to spontaneous side reactions with impurities inside the anode, the electrolyte, the cathode. There are power conversion losses between the battery and the MGU-K. The MGU-K is not 100% efficient. All of these systems also have variable thermal degradation due to their designs.
So tying hybrid system tokens to ICE index in a 50/50 formula where the hybrid system is important is simply flawed. Red Bull by virtue of their position as the "ICE leader" on paper (which may have no useful connection considering power band), has now been locked out of upgrading their hybrid system until 2028, while everyone else will receive minimum 1 update per season on the hybrid side. This penalty is applied to a 1st time PU manufacturer, who undoubtably would have far more things to correct on the hybrid side than manufacturers who have been making hybrids for over a decade. #-o
The system doesn't work. It's really simple to understand. Anybody who doesn't think Mercedes has the highest performing PU is simply not worth the time to argue with. The unanimous surprise in the paddock says it all.
The ADUO system will now allow the true lead PU manufacturer upgrades that completed defeat the catchup mechanism while hindering a 1st time PU manufacturer who without a shadow of doubt would be in a weaker position in areas that they are now forbidden from updating until 2028.
Beware of T-Rex
