Lotus E22 Renault
kwanchepan
kwanchepan
Re: Lotus E22 Renault
Very strange.
oT v1
oT v1
jesus what happened to the car when Pastor took it out? did they confirm brake problems? then there's the smoking cockpit...
The Power of Dreams
jagunx51
185
Blackout wrote:Very different exhasut layout compared to the other (Renault) teams
http://img1.auto-motor-und-sport.de/Lot ... 764132.jpg
(Or they didnt mount them yet in the pic?)
Edit
http://img1.auto-motor-und-sport.de/Lot ... 764138.jpg
do you have the exhaust pic for other renault car ?
i dont think rb10 has crumpled-pipes like e22, rb10 sidepod is mostly for heat exchanger, imo
basti313
basti313
32
oT v1 wrote:jesus what happened to the car when Pastor took it out? did they confirm brake problems? then there's the smoking cockpit...
When he ran into the gravel it looked like 30kp/h...I do not believe that this was only a brake problem. They were talking about a broken wire killing the battery...so maybe MGU K engaged all the time?
Don`t russel the hamster!
basti313
basti313
32
edit
Grosjean left the track because his rear left suspension was broken. You can see it in the vid.
timbo
timbo
113
Blackout wrote:Grosjean left the track because his rear left suspension was broken. You can see it in the vid.
But it broke because he hit the wall when he lost rear end under braking. At least it looked that way.
But Gro said the susp broke before! I don't know.
Take a look at the Caterham and RBR thread Jagun ; )
New engine cover: (similar to the 3d Reder one)
And a modified RW endplate
+ a snow plough between the tusks (onicorse)
timbo
timbo
113
Blackout wrote:+ a snow plough between the tusks (onicorse)
http://www.omnicorse.it/img/articoli/ev ... itter_.jpg
Wow, that is interesting! I had the impression that rules forbid closed cross-sections like that. Or is cross-sectional rules only for certain dimensions relative to center-line and reference plane?
iotar__
basti313 wrote:By the way:
Grosjean 1
Maldonado 0
but it was very close to have a 1:1.
This kindergarten doesn't belong here. Broken suspension.
kwanchepan
kwanchepan
Like RedBull in Jerez... but RBR added the air outlets near the intercoolers, on each sidepod, while Lotus opend that outlet only on the left side near the rads...and the air-water intercooler? Many suspect Lotus is using an air-water one unlike the other Renaul teams.
But only on Grosjean's car AFAIK...
CottrellGP
CottrellGP
Hi all i don't browse the F1 section lots but i have some questions... it has probably been mentioned before, why is one of the tusks on the nose cone longer than the other, why is the exhaust exiting to one side and is it true they only test half of the car in the windtunnel and the other half CFD, thanks all.
Dan Cottrell
Master Of Innovation!
