Flexiwings 2025
Re: Flexiwings 2025
CjC wrote:
29 May 2025, 16:59
29 May 2025, 16:57
Mclaren's wing from Imola had molding provisions for the update. You can see them in the old wing:
https://i.postimg.cc/90VsVPv9/image.png
Awesome spot. Aligns with the rumour Mclaren already ran a compliant wing (not entirely) this season.
So the carbon fibre weave mustn’t have changed just the bracket and adjuster?
The rumor I saw (by not very credible Ted Kravitz.) was that Mclaren's wing was already TD compliant (That is clearly not true: https://www.f1technical.net/forum/viewt ... 5#p1288695).
Regarding whether they changed the carbon fibre layup, I don't know but it doesn't matter. The wing before Spain wouldn't have passed the test, and if adding the slot gap separators and modifying the adjuster makes it more rigid, then they will pass the new test.
CjC
CjC
Re: Flexiwings 2025
SB15 wrote:
29 May 2025, 17:03
CjC wrote:
29 May 2025, 16:59
29 May 2025, 16:57
Lot's of you don't understand that this change does immensely effect aero balance.
Awesome input. Thank you for your technical explanation to my misplaced beliefs
Just a fan's point of view
SB15
SB15
Re: Flexiwings 2025
CjC wrote:
29 May 2025, 17:16
29 May 2025, 17:05
CjC wrote:
29 May 2025, 16:59
@SB15 this is the type of post you should aspiring to achieve
It still doesn't disprove my point. High speed cornering will be affected due to how much the wing the car is carrying, which leads to offset in terms of aero balance.
The Ferrari doesn't look to be effected by the TD as much because their front wing had the least flex of out the top 4 teams.
CjC
CjC
Re: Flexiwings 2025
29 May 2025, 17:05
CjC wrote:
29 May 2025, 16:59
29 May 2025, 16:57
Typical F1 it’s full of ‘half-truths’ which then get spun as stone cold hard facts.
Ted probably knew that the weave was compliant but it needed the brackets to make it fully compliant but he wanted to be the big news breaker so told a ‘half truth’.
Like Gary Anderson said, no team will rock up to Spain without previously testing the a compliant wing before hand.
Re: Flexiwings 2025
Luscion wrote:
29 May 2025, 18:06
reposting
SB15
SB15
Re: Flexiwings 2025
29 May 2025, 18:09
Luscion wrote:
29 May 2025, 18:06
reposting
You think they ran it during pre-season testing?
Luscion
Luscion
117
Re: Flexiwings 2025
SB15 wrote:
29 May 2025, 18:26
29 May 2025, 18:09
Luscion wrote:
29 May 2025, 18:06
reposting
Norris tested it in FP1 at Imola
chrisc90
Re: Flexiwings 2025
Luscion wrote:
29 May 2025, 18:33
SB15 wrote:
29 May 2025, 18:26
29 May 2025, 18:09
reposting
Was there any wing footage?
Re: Flexiwings 2025
chrisc90 wrote:
29 May 2025, 18:42
Luscion wrote:
29 May 2025, 18:33
SB15 wrote:
29 May 2025, 18:26
skimmed through the onboards and I can't detect it.
chrisc90
Re: Flexiwings 2025
29 May 2025, 18:45
chrisc90 wrote:
29 May 2025, 18:42
Luscion wrote:
29 May 2025, 18:33
Here you go. Ill see if there's any off Oscar.
Thats still flexing a lot if that's their TD compliant wing.
Luscion
Luscion
117
Re: Flexiwings 2025
Autoracer saying they tested it in Imola
https://autoracer.it/it/retroscena-mcla ... barcellona
Re: Flexiwings 2025
chrisc90 wrote:
29 May 2025, 18:51
29 May 2025, 18:45
chrisc90 wrote:
29 May 2025, 18:42
ah sorry, I meant I saw the wing and couldn't detect that it was stiffer :lol:
Maybe that's the lesson here...
Re: Flexiwings 2025
Update not visible in the first run from FP1 (Imola).
SB15
SB15
Re: Flexiwings 2025
f1isgood wrote:
29 May 2025, 18:49
29 May 2025, 18:09
Luscion wrote:
29 May 2025, 18:06
reposting
Could just be lying lol. We will know tomorrow.
Apparently, Gary Anderson is suggesting Redbull and Ferrari will get heavily impacted by the new TD which I don't believe be we'll see tomorrow. They also mentioned that the Mercedes will probably become unstable in the high speed dude the CoP shifting further front. Looks like Merc planned it and decide to run a more heavily loaded rear wing this weekend.
Re: Flexiwings 2025
The stiff wing was on Lando's car during second run in FP1 (Imola). They also had flow viz on the left rear suspension. He did a single hot lap on used soft with it, and then boxed again.
