Mclaren MCL40
Macklaren
Macklaren
Re: Mclaren MCL40
05 Mar 2026, 10:54
Melbourne (Albert Fabrega):
Also what's with the backwards facing camera below allwyn? Doesn't look like the normal winglet cam
And the shape of the entire engine cover looks much more concave and tighter than testing?
Re: Mclaren MCL40
Beware of T-Rex
Def
Def
Re: Mclaren MCL40
De Wet
Re: Mclaren MCL40
BigBeansBoy wrote:
05 Mar 2026, 15:42
De Wet wrote:
05 Mar 2026, 14:57
https://i.ibb.co/G4sb5wWQ/image.jpg
Changes I have noticed. Looks like the Beam Wing (4) has a lower angle.
1. Is the standard part from the FIA so it can’t have changed
Thx for info. :D
the EDGE
the EDGE
68
Re: Mclaren MCL40
A close look around the MCL40
the EDGE
the EDGE
68
Re: Mclaren MCL40
Changes in Australia are as follows:-
New floor edge geometry, resulting in better flow control around the rear tyres aiming at improved floor and rear corner aerodynamic load.
New fairing around the Rear Suspension mounting points resulting in improved flow conditioning around the Rear impact structure aiming at improved diffuser performance
A new Rear Wing geometry featuring revised mainplane and flap elements, gaining aerodynamic load throughout all conditions while maintaining efficiency
https://www.fia.com/system/files/decisi ... ssions.pdf
De Wet
Re: Mclaren MCL40
Would be nice to have frontal view.
De Wet
Re: Mclaren MCL40
@carpentiersf1:
SilviuAgo
184
Re: Mclaren MCL40
Piastri and Norris with a different rear wing design, flow-vis for Norris' wing
Re: Mclaren MCL40
SilviuAgo wrote:
06 Mar 2026, 17:28
https://pbs.twimg.com/media/HCuWpz4XIAA ... name=large
It would be interesting to look in the telemetry to see how top speed is affected, but then we won't know if it's just different deployment.
Beware of T-Rex
Emag
Emag
137
Re: Mclaren MCL40
06 Mar 2026, 20:08
SilviuAgo wrote:
06 Mar 2026, 17:28
Oscar was generally higher most of the laps I checked but not sure if it was a case of Lando running more conservatively.
Developer of F1InsightsHub
SilviuAgo
184
Re: Mclaren MCL40
Nose cone, OP81, Melbourne.
Owen.C93
Owen.C93
192
Re: Mclaren MCL40
Concerning that it snapped like that. Very in line with the adjuster. FIA might take a look at that failure mode.
SiLo
145
Re: Mclaren MCL40
Owen.C93 wrote:
08 Mar 2026, 20:55
That’s the mandated part of the nose that’s meant to crumble I think. The actual crash structure is rearwards of it.
Felipe Baby!
SilviuAgo
184
Re: Mclaren MCL40
I gathered some MCL40 pics in Australia
vs Mercedes
Not a nice ones:
