I think it's more a case of whether or not the driving style needs that much front grip. For example I don't think Jenson needs enough front grip for a car to be called pointy. He just needs the car to have enough grip to not understeer.Mandrake wrote:If pointy means very good turning at the front but not losing grip at the rear, which driver would not love to have that???
Ah... but why not? When you have 2 drivers who like oversteer?yener wrote:It will unbalance the car.
So you'll get tons of oversteer.
I find that it's down to preference really. I personally can find stability in both, but I prefer oversteer, especially with my old semi-pro drifting; but some people actually find it easier to control understeer. Straighten the car, and brake. It's slow, but aside from that to control isn't too hard. Though I'm still rubbish at it.wesley123 wrote:I dont get the point. both drivers love oversteer, and personally when i play rFactor or so I tend to make the car really oversteery, apart from that oversteer is much easier to control then understeer, it is also more enjoyable.
Wes; yener's point is that the car is lacking rear df and only has good front df.wesley123 wrote:The W02 is lacking downforce as whole, therefore it isnt unbalanced, and if it was, wouldnt you think they would add much more rear downforce?
Sure it is still preference, but from my own driving style(although in games), and what I hear from others, most of the pick oversteer above understeer. Understeer is something I'd expect button to drive with this, it requires much calmer driving.raymondu999 wrote:I find that it's down to preference really. I personally can find stability in both, but I prefer oversteer, especially with my old semi-pro drifting; but some people actually find it easier to control understeer. Straighten the car, and brake. It's slow, but aside from that to control isn't too hard. Though I'm still rubbish at it.wesley123 wrote:I dont get the point. both drivers love oversteer, and personally when i play rFactor or so I tend to make the car really oversteery, apart from that oversteer is much easier to control then understeer, it is also more enjoyable.
[/quote]Wes; yener's point is that the car is lacking rear df and only has good front df.wesley123 wrote:The W02 is lacking downforce as whole, therefore it isnt unbalanced, and if it was, wouldnt you think they would add much more rear downforce?
More drag then. Most the main planes for all the cars are about the same. not much you can gain on the RW (not including DRS!). pretty much standard territory.yener wrote:I agree the car is lacking on both front and rear side. But if you watch the 1 part of the season (especially the start) you can see and compare the grip on the rear side of the car.
Then they upgraded the rear suspension and that probably solved a part of the rear issue.
Then still I find it strange that they only have worked on a complicated exhaust system to find more DF at the rear while a modified rear wing would do probably the same.
They could still have a oversteering car if they would have a bigger (better) rear wing than they use now.
Disagree with the point, if that was the case Mercedes would most likely drop on a bigger rear wing. The whole car is lacking df and oversteer is just a setup preference, not an issue of the car[/quote]wesley123 wrote:Sure it is still preference, but from my own driving style(although in games), and what I hear from others, most of the pick oversteer above understeer. Understeer is something I'd expect button to drive with this, it requires much calmer driving.raymondu999 wrote:I find that it's down to preference really. I personally can find stability in both, but I prefer oversteer, especially with my old semi-pro drifting; but some people actually find it easier to control understeer. Straighten the car, and brake. It's slow, but aside from that to control isn't too hard. Though I'm still rubbish at it.wesley123 wrote:I dont get the point. both drivers love oversteer, and personally when i play rFactor or so I tend to make the car really oversteery, apart from that oversteer is much easier to control then understeer, it is also more enjoyable.
