roon
roon
412
Re: 2021 Aero Thread
Looks pretty good without wings, no?
santos
santos
Looks like a hot rod. For fun, it would be nice to see them doing a few laps without wings. Just the nose cone because of the crash structure.
trinidefender
trinidefender
318
Why not reduce the minimum weight limit. The teams know with the current weight limit they can make light cars that end up huge. Reduce the minimum weight limit and the cars will get smaller naturally. The teams won't want to make cars much over the weight limit.
FPV GTHO
FPV GTHO
Reduced weight without also reduced dimensions would favour the big teams, who would still be able to make large cars but potentially meet the weight limit.
mzso
mzso
68
trinidefender wrote:
16 May 2019, 21:10
The size should be reduced not weight. The latter would only accomplish discrimination against taller/heavier drivers.
trinidefender
trinidefender
318
mzso wrote:
24 May 2019, 00:30
16 May 2019, 21:10
No it won't. There is a rule for 2019 that sets a minimum weight for the driver.
Secondly the issue with setting size limits is that it is just one more box for teams to be confined to making the cars closer and closer to spec. Setting a lower weight limit will force some cars to go for longer cars with higher downforce that are above the weight limit while others will go for shorter cars that are closer to the weight limit.
The point was made above that this will lead to the richer teams spending millions of reducing weight and getting an unfair advantage except there are two issues with this statement.
1. Cars are already built under weight and then ballasted up to minimum weight by all teams therefore it is evident that no team really has trouble meeting minimum weight limits, it just allows the rich teams to build a long car at the weight limit for very high downforce while a poorer team will meet the weight limit but will have to use a smaller car.
2. The budget cap coming takes away the advantage of teams spending millions on making their cars lighter.
It will add variety to designs keeping things interesting and unpredictable and make the cars smaller at the same time.
I'm all for moving away from the current system of heavily regulations to try to force closer racing and would much prefer the budget cap system to allow closer racing. If all teams compete on similar budgets then you can be damn sure that there will be far closer parity between cars and more variety in winners from one weekend to another.
MatsNorway
MatsNorway
You can not make rules that will not favor the big teams. You can only make the sport relatively cheaper.
Dropping the weight limit has many benefits.
1) By dropping the weight it becomes a limit to how complex systems can be and still make the desired weight.
2) Less weight = less materials = less costs
3) Less weight = easier to flip car over by crew on track
4) Less weight = easier to stop a car in catch fencing
5) Mechanical grip goes up -> you can reduce aero -> potential for closer racing
6) Less weight will make the cars shorter, for some reason people think long cars is a problem.. it is not.
A touch of genius is the simplest thing.
DRS is like supports on a bicycle[/size]
mzso
mzso
68
24 May 2019, 03:44
80kg, which is below the taller driver's natural weight, such as Hülkenberg, Ocon, Albon, Russel.
Besides, the ballast will be around the center of gravity as I remember, meanwhile taller people have longer legs, which have more mass.
MatsNorway
MatsNorway
I thought the weight was to be added behind the back of the driver.
Maritimer
Maritimer
19
MatsNorway wrote:
24 May 2019, 23:52
Making the cars lighter will make them more expensive.
MatsNorway
MatsNorway
At least start by disputing my bullet points so i can see where you get that from.
Holm86
254
MatsNorway wrote:
27 May 2019, 11:58
Your theory is completely wrong. The cars still need to pass some collision tests, so you cant just make them lighter with less material, you still need to keep the strength of the chassis, and thats much more difficult with less material.
Even now, the small teams are suffering, because they cant build the cars light enough to fit the current weight limit ...
techF1LES
176
Proposed floor of the 2021 F1 car (Source: Sam Collins/Racecar Engineering)
jjn9128
780
techF1LES wrote:
28 May 2019, 09:53
Hmmmm interesting.... looks slightly different to the last spec shown off (e.g. no end-fences on the inlet to the floor), but it's hard to tell as it's mostly obscured by blurry CFD.
I don't hold much hope for the next generation of F1 cars... the tyres will still be crap so even if the aero is sorted the drivers won't be able to push.
#aerogandalf
MatsNorway
MatsNorway
Holm86 wrote:
27 May 2019, 15:03
How heavy is the carbon tub? and how heavy is the car? I doubt making the tub strong enough is the main reason the car is that heavy. The reason the car is that long is because it is allowed to be that heavy. Without a max length rule in the future( i am against) the cars will slowly creep up in length for aerodynamic reasons.
