Alpine A526
wiktor977
wiktor977
43
Re: Alpine A526
wiktor977
wiktor977
43
Re: Alpine A526
This front wing is very different than others, the main plane connects almost in the middle of the endplate and there are fences below on each side
Re: Alpine A526
wiktor977 wrote:
26 Jan 2026, 13:27
It's clear that this Alpine has had a lot more time being developed in a windtunnel than other cars. It might be due to their additional windtunnel resources and more sacrifice of 2025 compared to others.
Beware of T-Rex
wiktor977
wiktor977
43
Re: Alpine A526
Alpine similar to the Ferrari uses a front bib for some aero management. Sidepods look very 'Alpine-like', similar shape to previous years with VERY shallow waterslides
wiktor977
wiktor977
43
Re: Alpine A526
26 Jan 2026, 13:29
wiktor977 wrote:
26 Jan 2026, 13:27
True, but I personally think that they had to go very conservative in some areas. They are not in a position to take a big risk, at least now
MrRage
Re: Alpine A526
Re: Alpine A526
The drs is unusual. They drop the trailing edge rather than raise the leading edge
SICK AL SPEEDSHOP
Re: Alpine A526
just read an article on motorsport that Alpine is the only team that flaps down the rear active wing. all other teams that participated to the shakedown so far flap their active rear wing up. clever idea.
maybe they follow a total different concept with the front wing fixed in the middle of the endplate and they also are next to Cadillac using pullrod instead of pushrod at the front.
chlebekf1
chlebekf1
Re: Alpine A526
I also just read that the rear wing folds down instead of opening
Giando
93
Re: Alpine A526
Does this system allows a less erratic disruption of the airflow in the quick moment the wing pass from X to Z config?
Less momentary turbulences maybe?
GrizzleBoy
GrizzleBoy
Re: Alpine A526
I wonder if it that rear wing upper flap movement could also be more effective at reducing the diffuser efficiency on straights by reaching further back and lower down to disturb the downstream flow of the diffuser.
The exposed tips of the top of the endplates are basically additional upward facing winglets.
Could they be made to create strong vertices that other DRS designs are unable to make to create further disruption and further reduce drag?
Re: Alpine A526
chlebekf1 wrote:
29 Jan 2026, 17:52
That's innovative if true.
Beware of T-Rex
chlebekf1
chlebekf1
Re: Alpine A526
29 Jan 2026, 18:50
chlebekf1 wrote:
29 Jan 2026, 17:52
this is true, you can see it in the picture above
Re: Alpine A526
29 Jan 2026, 16:57
What corner is this? Looks like exit of T12 or T13?
Beware of T-Rex
johnnycesup
johnnycesup
Re: Alpine A526
29 Jan 2026, 19:09
29 Jan 2026, 16:57
https://i.ibb.co/FbFKmDXv/20260129-140806.jpg
https://upload.wikimedia.org/wikipedia/ ... o_2021.svg
That's the exit of 9, and the building in the background is the bridge with the TAG Heuer logo in the 2025 gp.
