Alpine A526
Madhouse
Alpine A526
Car thread.
hollus
Re: Alpine A526
The usual reminder of the rules for car threads:
Car threads (the crown jewels of this site) are moderated more strictly than other threads and are meant to focus on the hardware and interpretation of how it works. Deletions will be frequent for excursions off topic. Why that rear wing will reduce drag is on topic, how that rear wing will give you a podium is not on topic.
We want them to be ultra focused and not unusably long.
- The thread will open when there is actual decent pictures of actual hardware, or at least a convincing render. Until then, plese, stick to the speculation threads or the team threads.
- No discussion of livery or drivers in the car threads, use the team threads for that.
- Posts about lap times, about track position and about wining and losing belong in the team tread, race threads or bespoke threads, but not in the car thread. They may be sniped mercilessly if in a car thread.
- Hypotheticals are also better suited for the team threads, please stick to pieces that have appeared or obviously will appear on the actual car.
- Car comparisons are OK as long as they focus on THIS car. For comparisons of all cars, please use team threads, race threads or comparison threads.
¡Puxa Sporting!
FW17
184
Alpine A526
Autoracer: Alpine A526 has already hit the minimum weight requirement of 768 kg.
FW17
184
Re: Alpine A526
Badger
Badger
46
Re: Alpine A526
Looks like Alpine has opted for the bulky sidepod and big sidepod inlet with less centreline cooling compared to Racing Bulls. Interesting to see the differentiation already.
Also less rake?
FW17
184
Re: Alpine A526
Badger wrote:
21 Jan 2026, 15:27
Also less rake?
Looks like a bit of rake considering how close to the road the front foot plate is
Jambier
Re: Alpine A526
Ugly livery.
That’s great if they are already at the weight, plus having the best engine they should progress quite a lot this year
FW17
184
Re: Alpine A526
chlebekf1
chlebekf1
Re: Alpine A526
I hope it will be a big step forward
FrukostScones
Re: Alpine A526
"I ain't with the FIFA, I'm in Tokyo." LH
FW17
184
Re: Alpine A526
Pull rod fronts
F1ern
F1ern
16
Re: Alpine A526
Front pullrod, wide sidepods, huge air intakes at the sides and on the top as well.
lio007
327
Re: Alpine A526
Pullrod at the front.
Badger
Badger
46
Re: Alpine A526
Push rod rear. It also has front support struts for the floor.
Pull rod front. Large sidepod inlets. Normal airbox size. Absolutely massive anti-dive geometry on the front.Image
FW17
184
Re: Alpine A526
Did they copy Mclaren suspension from last year?
