There is no exception. If there was there would be no penalty at all.Shooty81 wrote:In the interview Lauda said there is an exception to avoid "terminal failure".smellybeard wrote:Exactly.dans79 wrote:That's going to guarantee all the teams will do it in the future!
Merc have gained a third place from breaking the rules.
Who says crime doesn't pay.
Using an exception is not breaking the rules.
smellybeard wrote:There is no exception. If there was there would be no penalty at all.Shooty81 wrote:In the interview Lauda said there is an exception to avoid "terminal failure".smellybeard wrote: Exactly.
Usual team BS.
Agree with all of the above, with the exception of the penalty. If he hadn't been told what mode to go to and then how to workaround the issue I'm pretty sure he would have finished much lower down. Rules and rules, he should have been DSQ.ringo wrote:Foxhound,
He didn't have a reliability problem. Engineer's are the only ones that can solve those problems.
I see what you are getting at, but he did not have a reliability problem in the true sense. There was some kind of glitch.
And it should have been left up to him to decide how to manage the gearbox.
Reliability problems are solved at the factory, not on the race track.
The most that could have been argued is safety, and in no was was Nico's safety at risk.
Nico gets all the info on his steering wheel to know what his problem is. Similar to how all the drivers can see brake temps. Mercedes knew they were going to lose the 1-2, it wasn't about reliability at that stage. His penalty was rightly judged and deserved.
Shooty81 wrote:smellybeard wrote:There is no exception. If there was there would be no penalty at all.Shooty81 wrote:
Usual team BS.
As far as I know there is no penalty yet. I think there is this exception. The open point is just if this exception was applicable in that case and that takes so long. How do they judge if there would have been a terminal failure...
A glitch which would have led to a gearbox failure. It's still a reliability issue, which could and was overcome using radio message instruction. It was not a racing instruction.ringo wrote:Foxhound,
One is against the rules, the other isn't.FoxHound wrote:Yet Red Bull's message informing Vers of investigation, and thereby stopping any actual racing, was ok?
It appears you value the current radio messaging ban, and not actual racing.
He got instructions how to shift from 6 to 8th. That the problem. He would have been third with 1-6. Now he was second.FoxHound wrote:A glitch which would have led to a gearbox failure. It's still a reliability issue, which could and was overcome using radio message instruction. It was not a racing instruction.ringo wrote:Foxhound,
If we use this as a a template for punishment, we are on dangerous ground.
Potential issues like engine overheating, brake failure, gearbox failure or possible failure within the car, that can be fixed otherwise, would result in the driver retiring. Worse than that, if the problem could be fixed, but isn't, it could result in dangerous failure resulting in injurious accidents.
Is this really what we all want?
Properly brainless this rule, properly!
Again, he was penalized, because he asked a question of how to work around a future issue, that the team told him.FoxHound wrote: Is this really what we all want?
Agreed. How many DNFs could have been avoided this year if the other teams had just broken the rules to tell their drivers how to fix terminal mechanical problems. For some teams (FI and Sauber come to mind) that could be the difference between being on the grid next year or not.ChrisM40 wrote:This whole situation is hateful, and its entirely the FIAs fault.
