Red Bull RB22
euv2
euv2
Re: Red Bull RB22
Here you go! :shock:
📷 Giorgio Piola
ME4ME
82
Re: Red Bull RB22
Nice.Wonder how long that'll hold. Looks fragile.
Re: Red Bull RB22
Diffuser extensions for lateral expansion
Re: Red Bull RB22
euv2 wrote:
20 Feb 2026, 12:07
📷 Giorgio Piola
What would be the purpose of this?
#ReleasetheADUO
Re: Red Bull RB22
You can see the spatula winglet here behind the FW. Given its position when mounted, looks highly likely it's helping to manage lower tyre wake. Probably interacts strongly with the FIA spec deflector part
Re: Red Bull RB22
20 Feb 2026, 12:23
Yes I remember you asked about it yesterday, but I got sidetracked trying to find real floor inlets :lol:
#ReleasetheADUO
f1isgood
f1isgood
Re: Red Bull RB22
What loophole are they exploiting here? How will this help? More front downforce?
Re: Red Bull RB22
The famous RBR flap trim is gone.
It has been traditionally done to remove the bit of surface that tends to separate because of the DRS actuator like on this Audi.
#ReleasetheADUO
pantherxxx
pantherxxx
Re: Red Bull RB22
That's like a double diffuser equilavent in"terms of loophole"? :shock:
euv2
euv2
Re: Red Bull RB22
https://x.com/xavigazquez/status/202482 ... 96435?s=20
Can see how the diffuser extension is connected.
vorticism
vorticism
449
Re: Red Bull RB22
Their FLED interpretation is interesting. One large FLED with four smaller FLEDs daisy-chained upon it.
Regarding the spatula fence and serrated diffuser fence: these are the sorts of shapes we’ll see on the FW fences & diffuser fences. Alpine brought a cantilevered FW fence. These and others I alluded to last year:
viewtopic.php?p=1300140#p1300140
viewtopic.php?p=1300481#p1300481
Nice thing about the fences: there’s no camera trained on them, and they don’t (afaik) have a deflection test. Aeroelasticity complicity? Implicitly? We shall see...
20 Feb 2026, 10:53
venkyhere wrote:
19 Feb 2026, 15:55
https://i.ibb.co/Gv0SHVjP/RB22-new-side ... -test2.png
Now that the undercut has appeared, and the 'floor extension' gone, we are seeing the floor entry very clearly. Is this (green encircled) a 'venturi tunnel like' entry hugging the tub's wall, @vorticism ? Do all teams have it ?
Good spot...
Nicolas Carpentiers has given us this image:
https://i.postimg.cc/P5NB1xwQ/20260220-084829.jpg
Which confirms your findings. Red bull seem to have recreated the floor entry of venturi cars. I would speculate that this is only possible with the sidepod extension that Vorticism previously discussed, the underneath of which is the roof of this venturi-like entrance?
The 3d shaping of the bib area as a whole is probably the most interesting detail of the car
https://i.postimg.cc/nrk6G92v/20260220-084829.jpg
It may help, although it’s still present here on the undercut version of their sidepod i.e. reduced or omitted overhang. It’s still interacting with the down-sloping fore-chassis/footwell (legwell?), regardless. Quite a complex interaction. Looks smart, at least.
lio007
327
Re: Red Bull RB22
Detailed flow-vis picture:
Re: Red Bull RB22
You can see the air turning down in front of the undercut and going into the inboard floor inlet. It’s a big difference compared to the launch spec sidepod. The flow control in this area is impressive. I suspect that they are going to keep undercutting deeper and deeper.
#ReleasetheADUO
venkyhere
43
Re: Red Bull RB22
The flowvis on the 'bargeboard' stay (bigger flatter stick) in the x-direction is something I didn't expect. With the venetian blinds receiving high pressure air in the x-y direction from the keel section below the driver's feet, I would have expected the wheel wake to start moving in x-y direction a bit before the stay itself. Or is this a simple case of flowvis that got 'spread' before hitting meaningful speeds ? I am most likely wrong in the way I am perceiving the way the venetian blind are expected to work (+x +y +z direction) and the stay rod seeing x-y air before hitting the venetian blinds ; but somehow I have a feeling that it would have been different with the bluff-sidepod vis-a-vis the moisture shots we saw from Barcelona test.
Re: Red Bull RB22
venkyhere wrote:
21 Feb 2026, 20:31
The blinds are not getting air from the keel section under the driver's feet. They are receiving the tire wake. The tire wake turns 90 degrees and then goes up and outboard right behind the tire.
Tire wake is turbulent so the flow viz that you see on the stay associated with the tire wake will be incoherent. That's what turbulence is.
#ReleasetheADUO
