I thought I counted them all, and there were still more.AR3-GP wrote: ↑26 Mar 2026, 03:40The amount of mini-ducts is insane.
@n_mode_log
https://pbs.twimg.com/media/HETMzSza0AE ... name=large
@n_mode_log
This looks more insane than last yearAR3-GP wrote: ↑26 Mar 2026, 03:40The amount of mini-ducts is insane.
@n_mode_log
What is in the nose that needs to be actively cooled with a fan? Surely this hole is supposed to be only for driver cooling or are they using it to cool some other component too?
Other than the actuator for the wing, which surely doesn't really need cooling siting in the garage I can't think of anything. Other than maybe a little bit of debris from working in the footwell and they wanted to blow it all out with a fan?Just_a_fan wrote: ↑24 Apr 2026, 10:00What is in the nose that needs to be actively cooled with a fan? Surely this hole is supposed to be only for driver cooling or are they using it to cool some other component too?
Looking at the front of the tub, there doesn't look to be much space for airflow from the nose in to the tub anyway. I wonder if they have an electronic box in the nose controlling the front wing actuator and that needs cooling.SiLo wrote: ↑24 Apr 2026, 10:28Other than the actuator for the wing, which surely doesn't really need cooling siting in the garage I can't think of anything. Other than maybe a little bit of debris from working in the footwell and they wanted to blow it all out with a fan?Just_a_fan wrote: ↑24 Apr 2026, 10:00What is in the nose that needs to be actively cooled with a fan? Surely this hole is supposed to be only for driver cooling or are they using it to cool some other component too?
Since this year (?) it must be in the monocoque area. I think this cooling is for the front adjustment system. Maybe to hold a (gas) pressure system (tank) at the right pressure window.
