Diesel wrote:roost89 wrote:
Agreed, I think everyone accepts it works for overtaking etc. I think the main argument from teams is it's very expensive, and in times of cost cutting, does F1 really need the expense.
It's also a bit strange how it's restricted so heavily, surely to promote the green message these things should be storing and discharging as much energy as possible?
Good race today, it seemed overtaking was limited by the contraints of the circuit. It was really encouraging to see cars running so close to each other. Most drivers seemed to have problems with DRS because they weren't close enough, poor traction out of the last corner? The straight was then not long enough to reel in the car infront.
Malayasia will be a good test, we would have had both extremes then. A short point and squirt circuit, and a long sweeping circuit. I suspect the issue with DRS at Sepang will probably be the straight is too long! So I guess that's where they will think about a time restriction, like KERS.
From what I was hearing from the commentators, DC, Ant Davidson, Karun Chandhok et al. They fully expected the DRS-Zone to be between T2 and T3 as that had the greater opportunity for overtaking.
I agree with your statement that overtaking was constrained by the circuit, traction and a short DRS-Zone. I also believe that they should be allowed to store and discharge a greater volume, if you can have a volume of electricity. We may, then, see both the electrical and flywheel KER systems.
Tumbarello wrote:of course KERS helps. Just look how Hamilton was able to get back at Webber after his bad start.
My, rough, transcription of what Di Resta said was more to show that the DRS, on this occasion, wasn't effective at what it was designed for and that the previous "push to pass" system provided a better platform from which to initiate an overtake or defend.
However, with the DRS being the main-focus for an overtake the drivers were resorting to using their KERS more as a tactical measure instead of in set areas like the exits of corners to increase lap time, as it was in 2009.
"It could be done manually. It would take quite a while, but it could be done. There is however a much more efficient and accurate way of getting the data. Men with lasers." Wing Commander Andy Green
