Mercedes AMG F1 W09 EQ Power+
DiogoBrand
74
Re: Mercedes AMG F1 W09 EQ Power+
Owen.C93 wrote:
11 May 2018, 15:47
DiogoBrand wrote:
11 May 2018, 03:12
https://uploads.tapatalk-cdn.com/201805 ... 4d558e.jpg
https://uploads.tapatalk-cdn.com/201805 ... 82e504.jpg
I've seen that little flap on Sauber's car as well. Is it there to create some sort of outwash?
It looks like the vane is perpendicular to both arms when viewed in plan. I'm not sure what regulation is dictating that however.
Perhaps the regulation about the suspension arms being a neutral aero surface, so you could only have perpendicular flaps, which in theory are neutral.
cramr
cramr
DiogoBrand wrote:
11 May 2018, 15:59
Owen.C93 wrote:
11 May 2018, 15:47
DiogoBrand wrote:
11 May 2018, 03:12
If someone fancy some light easy reading:
https://www.fia.com/regulation/category/110
That should be around 10.3 Article
DiogoBrand wrote:
11 May 2018, 15:59
Owen.C93 wrote:
11 May 2018, 15:47
DiogoBrand wrote:
11 May 2018, 03:12
Nah.. Remember that rule about the legality volume where all bodywork is considered as a brake duct? It is exactly this at play here.
roon
roon
412
PlatinumZealot wrote:
12 May 2018, 01:36
DiogoBrand wrote:
11 May 2018, 15:59
Owen.C93 wrote:
11 May 2018, 15:47
Diogo may be right. These fins look farther inboard than the innermost parts of the brake duct assemblies. As pointed out, they are a vertically symmetrical arrowhead shape, and faceted in two planes perpendicular each to a suspension arm, with a permitted fillet joining the two planes together. The little holes are a mystery, though, not sure how they meeting the wording of the rules. Unless the correspond hole on the mirrored side is present but obscured within the suspension arm.
Essentially, these are local enlargements of the suspension arms.
Flex floor ?
More like broken floor, to be honest.
mantikos
mantikos
Just_a_fan wrote:
14 May 2018, 18:18
Agreed, clearly broken.
ScrewCaptain27
577
Failure or damaged by debris?
- Serj Tankian
Mercedes are testing new rain lights
[media]https://twitter.com/MercedesAMGF1/statu ... 0658076674[/media]
Winglets on the sidepod a la McLaren?
Photo via @ChrisMedlandF1
Be interesting to see if those VGs stay on the car. I wonder if they're there to compensate for the messy air coming off the pressure plot rigs up front...
JPBD1990
JPBD1990
51
Morteza wrote:
15 May 2018, 10:40
https://pbs.twimg.com/media/DdOZTojWkAA4cIC.jpg
Could just be the angle/lighting - but the engine cover looks vastly different. There’s like an indentation on top of the side pod at the front, and it appears more square shaped toward the rear cokebottle... anyone else see that?
I think there are bodywork changes, yes. Certainly, the tail of the bodywork stops at the rear wishbone attachment where previously the upper wishbone stuck out through holes.
RZS10
359
ninja'd
