This makes no sense at all.Moose wrote:The tin foil hats are well and truly on. Mercedes CLEARLY instructed drivers who got stuck in a weird engine mode to pretend to be stuck in a specific gear and have a race ending problem so that they could instruct them in how to reset the engine, rather than adding a simple control to the steering wheel to carry out the reset in a more simple way.stuartpengs wrote:I saw Rosberg stuck in 7th gear. I don't remember Hamilton suffering a similar fate in Baku.PlatinumZealot wrote:You all are falling for Mercedes deception! You got tricked hook line and sinker
There was no gearbox problem or any threat of losing the 7th gear or the entire gearbox for that matter.
Christian Horner noticed in the onboard video that Rosberg continued to use the 7th gear as normal after he did the "reset." He didn't even try to skip 7th or lessen his engine revs... And guess what? He didn't need to! Why? Because he had no gearbox problem but he had the same Engine problem that Hamilton had in Baku! The team only used the gearbox problem as a veil to pass the engine reset codes to Rosberg!
Don't you people see that?!
Rosberg was well clear of Verstappen when his car got stuck in 7th. If he had a "Baku setting problem" he would have lost around .6 max, still easily in front of Verstappen.
When stuck in 7th, he lost around 4 seconds while the team was clearing the setting "chassis zero" with race control. If race control would have waited a bit longer, verstappen would have passed him on track. So no, no special instructions to "forget" to change gear or whatever. Too risky and makes no sense.
The "chassis zero" was cleared by the stewards, no penalty there, no problem there. After that, his gearbox/whatever still played up so he had the 7th gear question that was incorrectly answered, with Verstappen on his back.
What advantage would Rosberg have to have his gearbox jammed for half a lap?
