Mercedes AMG F1 W09 EQ Power+
dren
228
Re: Mercedes AMG F1 W09 EQ Power+
turbof1 wrote:
23 May 2018, 14:58
How are they stuck on top of the sidepod? Ductape?
Flexseal so they are able to keep water out if the car goes into the harbor at Monaco.
I'd think they'd take bolts from the underside of the chassis or they are hollow and a bolt passes through them into threads on the chassis. I have no clue for sure, though.
Honda!
Maritimer
Maritimer
19
turbof1 wrote:
23 May 2018, 14:58
Captive stud id say
dren wrote:
23 May 2018, 15:03
turbof1 wrote:
23 May 2018, 14:58
Thanks for that. Maybe they are riveted in place and then flexseal over the sealing edge?
@Maritimer: seems a good suggestion as well.
Interesting that they choose to go down this route. The past couple of seasons featured a move away from VGs. Maybe the VGs are a more draggy solution, but given the circuit it might be beneficial for Monaco as they reduce lift on top of the sidepod.
Maritimer
Maritimer
19
Could the vortex they generate run down the bodywork and be used to help seal the diffuser? Like the old coanda exhausts. They'd want to follow the sidepod contours i would imagine.
dren
228
turbof1 wrote:
23 May 2018, 15:11
I was quite surprised as well since the field has moved away from them sans Mclaren. Maybe it's a one-off as you suggest for Monaco.
Honda!
dren
228
I don't think that's new Sevach.
Honda!
dans79
267
dren wrote:
23 May 2018, 16:01
It's not, check the 3rd from last picture in this post.
viewtopic.php?f=12&t=27059&p=754430#p754389
202 105 104 9 9 7
F1Krof
96
turbof1 wrote:
23 May 2018, 14:58
I imagine inverse bolts.
Wroom wroom
i think the vortex generators are glued on. They don't expeirence a lot of load.
The paper tells him where exactly to glue them.
zibby43
zibby43
New rear bodywork (top is new; less bodywork around rear suspension)? Chimney engine cover bolted on, as well.
[media]https://twitter.com/AlbertFabrega/statu ... 4683569158[/media]
zibby43
zibby43
Holm86
261
PlatinumZealot wrote:
23 May 2018, 20:09
I agree that they must be glued on, using bolts etc seems like a very heavy solution.
ScrewCaptain27
577
Holm86 wrote:
23 May 2018, 20:55
23 May 2018, 20:09
Small bodywork components such as strakes and VGs are usually bonded on with adhesives.
- Serj Tankian
Via AMuS
