Aston Martin AMR26
theWPTformula
50
Re: Aston Martin AMR26
Redragon wrote:
29 Jan 2026, 18:50
I brought the midlevels up so more detail
https://ibb.co/XZXjkV8Z
Rear suspension arm connections look interesting...
wiktor977 wrote:
29 Jan 2026, 18:43
29 Jan 2026, 18:38
wiktor977 wrote:
29 Jan 2026, 18:33
Some winglets, not seen so far on other 2026 cars
https://i.postimg.cc/4xYtCkY8/Aston-details.jpg
I don’t think the front one is a winglet, that’s the front of the halo, or a shadow
It's weird because in the picture from the side I also see something there but I it's very possible it's only a shadow. I don't think it's a halo because of the angle, it looks vertical
I agree, it's a winglet
Beware of T-Rex
GrizzleBoy
GrizzleBoy
theWPTformula wrote:
29 Jan 2026, 18:58
Redragon wrote:
29 Jan 2026, 18:50
Yeah wth is going on there
GrizzleBoy wrote:
29 Jan 2026, 19:01
29 Jan 2026, 18:58
Redragon wrote:
29 Jan 2026, 18:50
Is back leg is attached to the rear wing pillar? :shock: :shock:
Beware of T-Rex
FNTC
FNTC
One of the rear suspension arms is mounted to the rear wing pylon?
f1isgood
f1isgood
Interesting airbox.
GrizzleBoy
GrizzleBoy
Rear wimg AOA looks quite minimal.
GrizzleBoy
GrizzleBoy
29 Jan 2026, 19:02
GrizzleBoy wrote:
29 Jan 2026, 19:01
29 Jan 2026, 18:58
https://i.postimg.cc/PrvHw29M/image.png
Can't be surely.
Did AMR get caught out releasing AI slop or something
Redragon
The cover engine looks like it is wrapped around it as if it was sucked to max. You can see the shape of it
vorticism
vorticism
449
Big louver exit on the side, as I expected. What I suggested back in June.
vorticism wrote:
28 Jun 2025, 01:29
Skimming through the 2026 regulations, it seems to have some easter eggs. The biggest one may be the changes to wording of the engine cover & louver aperture allowances. They might provide the main visual differentiator of 2026: large unusual louvers. ...
https://i.postimg.cc/59YKnhSf/2026louve ... ssmall.jpg
https://twitter.com/athalkunni/status/1 ... 6148342914
vorticism wrote:
27 Jan 2026, 22:00
... Emphasis on narrowness around the rear suspension. I hope they turn a new leaf conceptually. Eliminate the familiar center cannon and do total louver efflux. ...
Can't tell if there is a center cannon at the rear or not. Traditional sidepod shapes, it seems, although very compact.
wiktor977 wrote:
29 Jan 2026, 18:33
The aft attachment points of the front arms are nearly touching. Structural efficiency there--two load paths sharing the same anchor.
Other items of interest:
--RB19 type sidepod inlet
--pushrod front & rear
--rear suspension arms mounted to the RW pylons
--large roll hoop wings
--large halo vanes
--two legged RWAS adjuster fairing?
--spoon shaped nosecone
wiktor977
wiktor977
43
Suspension on this car looks different
Brahmal
Brahmal
73
Front wing and bargeboard similar to Mercedes, nose very similar to Audi. Overbite sidepod with a strongly negative AoA front edge, which is different. Ferrari-like top intake, with little or no centerline cooling. Coke-bottle pinches down to a tiny central cannon, looks like the side cannons are vast majority of heat exhaust.
wiktor977 wrote:
29 Jan 2026, 19:06
https://i.postimg.cc/pL8PgqJw/Aston-rear.jpg
this might not be rear suspension. Could be a strut to support an aero sensor.
Beware of T-Rex
tomazy
tomazy
230
mzso wrote:
29 Jan 2026, 18:55
Why are the rear suspension arms seem to be floating in mid-air?
maybe the contact point of the suspension is not gearbox casing, but a pillar, similar to ehat Williams was running back in Maldonado days?
GrizzleBoy
GrizzleBoy
Attachment points either side of each rear wing support pylon it seems.
Higher up you put the suspension geometry, the more level it is when compressed?
