Doesnt matter if it led to a gearbox failure. Reliability problems shouldn't solved at the track. They can only be mitigated. And by the current regulations, they must be mitigated without the help from the pitwall.FoxHound wrote:A glitch which would have led to a gearbox failure. It's still a reliability issue, which could and was overcome using radio message instruction. It was not a racing instruction.ringo wrote:Foxhound,
He didn't have a reliability problem. Engineer's are the only ones that can solve those problems.
I see what you are getting at, but he did not have a reliability problem in the true sense. There was some kind of glitch.
And it should have been left up to him to decide how to manage the gearbox.
Reliability problems are solved at the factory, not on the race track.
The most that could have been argued is safety, and in no was was Nico's safety at risk.
Nico gets all the info on his steering wheel to know what his problem is. Similar to how all the drivers can see brake temps. Mercedes knew they were going to lose the 1-2, it wasn't about reliability at that stage. His penalty was rightly judged and deserved.
If we use this as a a template for punishment, we are on dangerous ground.
If the help was on safety grounds by all means the pitwall can radio in. But to say you want to prevent your car from failing so you tell your driver how to drive the car then that's still helping his performance.
Then so be it.Potential issues like engine overheating, brake failure, gearbox failure or ANY possible failure within the car, that can be fixed otherwise, would result in the driver retiring. Worse than that, if the problem could be fixed, but isn't, it could result in dangerous failure resulting in injurious accidents.
Is this really what we all want?
Properly brainless this rule, properly!
By the rules the driver is not supposed to be assisted. if his car fails, it fails.
It's a stretch to say a gear box failure is dangerous. A tyre failure, or riding the kerbs is more dangerous and we don't see the pit wall chiming in when those risks are imminent. to reiterate, reliability issues aren't fixed by the drivers, as those tend to be design or manufacturing issues which should be fixed outside of the race.
