Mercedes AMG F1 W09 EQ Power+
zibby43
zibby43
Re: Mercedes AMG F1 W09 EQ Power+
Conventional engine cover fin for Merc.
No vortex generators on the sidepods. 2 common-sense changes for this weekend.
[media]https://twitter.com/AlbertFabrega/statu ... 9075118081[/media]
ScrewCaptain27
577
Bulkhead with 3rd damper removed:
AMuS
- Serj Tankian
Not a hundred percent certain but it appears the sidepods are smaller. The area around the middle appears to be much more vertical than before.
F1Krof
95
wesley123 wrote:
07 Jun 2018, 10:49
I can't see any difference tbh. Looks the same. Probably it looks different without the sidepod wings.
Wroom wroom
djones
djones
The sidepod vortex generators didn't work, or that's only for a high downforce track?
djones wrote:
07 Jun 2018, 16:26
It does add some drag.
astracrazy
astracrazy
31
I doubt the additional downforce is worth the drag here. Its mostly a point a squirt circuit and teams usually bring low downforce packages.
Inverted rear wing
Via @AlbertFabrega
mantikos
mantikos
So some updates on both the diffuser and bargeboard area
What are these bulbous things, I noticed the Williams has it too.
On the Williams there are wires running to the lumps which suggests sensors of some kind. The Williams version looks very crude and must do no good for the airflow...
Perhaps they Laser Doppler Velocity sensors?
