Mercedes W12
DarthPlagueisTheVise
42
Re: Mercedes W12
Was Lewis running less rear wing than Valtteri today ?
Technical Noob
marcush
marcush
Re: Mercedes W12
Rake angle is a factor of rear vertical springrate (and low speed damping) vs
springrate , static rake angle is certainly different from dynamic figures ..
Static angles delta seems to be smaller
comparing RedBull and Merc.
balalev
balalev
25
Re: Mercedes W12
DarthPlagueisTheVise wrote:
01 May 2021, 17:38
Yep, different configuration
42
Re: Mercedes W12
balalev wrote:
01 May 2021, 21:43
01 May 2021, 17:38
https://www.racefans.net/wp-content/upl ... N-01-1.jpg
https://www.racefans.net/wp-content/upl ... N-38-3.jpg
Thanks for the pics.
Technical Noob
pursue_one's
97
Re: Mercedes W12
It's interesting.
mkay
mkay
16
Re: Mercedes W12
Is BOT's rear wing higher downforce, but offers more DRS benefits (due to taller/wider flap)?
Re: Mercedes W12
Higher downforce. No DRS benefit. The top speed dpesnt get higher but he will feel a bigger difference in speed when it opens up.
One of the advantages of being able to live with more rear tyre slip means a driver can take this low drag rear wing option. Sometimes it can back-fire though.
marcush
marcush
Re: Mercedes W12
PlatinumZealot wrote:
03 May 2021, 07:30
your post is a bit misleading in my view
is not an issue for any driver .Actually a
clear and honest oversteer characteristic is quite easy to control , if you have enough opposite lock available.
A tyre has a certain amount of grip available ,which can be split up into longitudinal and lateral load bearing capacity . Braking and Throttle application reduce lateral grip capacity .
So yes , different driving approaches lead to different car feedbacks .
if you brake deep into the corners you will need extra front grip ,to retain lateral grip while decelerating , if you finish braking before turnin , you have all grip of the front tyre for cornering .
But you cannot have more than optimum slip angle for a given vertical load and tyre temp and expect more grip .Grip peaks at optimum slip angle ,period .Exceeding this , and you lose grip )road holding capacity.It goes without saying Lewis is not quicker by living with higher slip angles at the rear .
aral
aral
26
Re: Mercedes W12
Could you please try and stay on the actual topic....W12 itself, rather than delve into driving styles etc. These can be discussed on the team thread.
Mr5in1
Re: Mercedes W12
Hi I read somewhere else that the Merc had updated engine maps to improve driveability, can anyone confirm or add comment?
I think this might be an explanation for them being fast on the main straight at the weekend i.e. a good drive out of the last corner, and a contributive reason why Lewis was able to overtake Max early on (on top of Max's exit error)
Mattchu
59
Re: Mercedes W12
I know the rake subject gets done to death, and I`m sorry about the poor picture quality, but I found this quite interesting.
Pretty much all the way round the corner the 2 cars were pretty much identical on the angle.
F1NAC
172
Re: Mercedes W12
Basically RB is more loaded on this photo ( front wing endplate proximity to the ground) merc is stiffer
Mattchu
59
Re: Mercedes W12
The suspension set up of the cars is different, but when the cars are actually travelling at speed I don`t think the rake angle is that much different [static to dynamic].
When the cars are static, the angle is more on the Red Bull, just watch the pass video [4th down] from the link below and pause -> start -> pause around the 17/18 second mark. The rake angle of both cars is very similar at all stages of the corner.
https://www.skysports.com/f1/news/31381 ... lton-trust
I`m just wondering if this is one of the reasons Mercedes seemed to have clawed back some performance and Aston Martin still seem to be floundering.
marcush
marcush
Re: Mercedes W12
Mattchu wrote:
03 May 2021, 19:22
As posted before ,static rake does not tell you what happens dynamically .
oversimplified you could say , more rideheight allows for more bump travel and you can soften springrate.
This is of course not taking into account
spring compression by aero generated vertical load compressing the springs .
Pyrone89
Re: Mercedes W12
Perhaps they increased the rake slightly and this solved their issues. Because it is light and day between Bahrain testing and the GP's
