Mercedes AMG F1 W06
BlackSwan
BlackSwan
Re: Mercedes AMG F1 W06
n_anirudh
n_anirudh
240
This car has a blown diffusser...
yup. That may explain their rear end grip. It's very suttle and passive, but the diffuser similar to the double diffuser days ia blown by free stream air. The difference is that the air comes from the outer flow to the side pod and is rammed in by a turning vain behind the wishbones. This air turns in toward the centre of the car and contacts that blocker under the crash structure. It also is accelerated throught the starter hole. this is a neat littlw trick that doesnt seem obvious at first. and as usual i think the other teams can copy this techniqe without nweding much resources. Aldo Costa seems to have the talent of making big developments very suttle and hard to find on the car. I guess the teams can start scrambling to copy this kind of double diffuser. I also think this was mercedes interpritation of mclarens butterlfy suspension but they tied it into the diffuser.Image
FrukostScones
I 'm pretty sure the "batwing" is the key.
"I ain't with the FIFA, I'm in Tokyo." LH
SectorOne
When in reality the whole car is the key. Everything on the car is working in total harmony.
NoDivergence
NoDivergence
52
That's what people don't get. They get all excited about size zero, cokebottle, rake, etc etc. There's no magic bullet on this car. The whole car is top notch.
ringo wrote:This air turns in toward the centre of the car and contacts that blocker under the crash structure. It also is accelerated throught the starter hole. this is a neat littlw trick that doesnt seem obvious at first.
It's a very neat trick considering that the starter holes are closed by flaps these days...
thomin
Ever heard of "marginal gains"? I believe that's what we're seeing here.
240
@just a fan - Whatever you want to call that multi wing thing under the crash structure. That good enough for you now? :wink:
SectorOne
Mercedes have made a change to the underneath of their nose section, which now has a ‘fat’ section (see arrow) on its underside that acts as an airflow passage. Mercedes have been able to make this alteration without having to homologate a new nose - the design is a cover of the original nose, meaning new crash tests were not required. The new section is fully integrated with the chassis.
http://www.formula1.com/content/fom-web ... -nose.html
dans79
267
I wonder where the inlet is?
202 105 104 9 9 7
scarbs
scarbs
393
There's no inlet, that opening is sealed by a panel attached to the bulkhead, leaving a smooth continuous under surface
tranquility2k4
tranquility2k4
Just wait for Merc to bring their upgrades to Malaysia. They didn't bring anything to this race - everyone is waiting for their 2015 front wing evolution. Their current FW is pretty similar to 2014. In a way they can decide to hardly bring any upgrades (and save money for the company) but still dominate.
scarbs
scarbs
393
Paddy Lowe told me there's only a few small bits and pieces coming for Sepang
dans79
267
scarbs wrote:There's no inlet, that opening is sealed by a panel attached to the bulkhead, leaving a smooth continuous under surface
Thank you, I was confused by the article, as it called it an airflow passage.
202 105 104 9 9 7
