Alpine A522
Re: Alpine A522
diffuser wrote:
13 Jul 2022, 16:31
Very interesting. What makes you think that curve piece goes any further back than that bridge 1" or so before the rad? Looks like it's designed to create a seal on that bridge.
Yes you're probably right
Re: Alpine A522
godlameroso wrote:
28 Mar 2022, 16:37
Blackout wrote:
28 Mar 2022, 11:24
Yes the car is definitely relying on the floor edge gurney to generate load in that area.
They're using the front of that undercut to turn airflow outwards (outwash) towards that gurney flap (yellow) to power it up, so it can also enhance air extraction from below the floor.
RB was doing a similar thing IMO in the first iteration, but with less agressiv edge wing/curl.
https://pbs.twimg.com/media/FO3LWiYXMAA ... ame=medium
As you can see the undercut is pushing that flow sideways, whereas the new RB sidepods moved away from that design and pushed the undercuts widest part backwards and inboard for a more streamlined shape
https://i.imgur.com/ITPIIJr.jpg
And those sidepods are wider than needed. They have plenty of empty space around the radiators and they are using that flap (green arrows) to seal the void between rad and bodywork, so the car can have much tighter sidepods if it wants.
https://pbs.twimg.com/media/FO3LYBMWUAI ... ame=medium
https://pbs.twimg.com/media/FO3PBcUXoAA ... name=small
Pics from Nextgen-auto and Motorsport images
https://files.catbox.moe/tbcrnf.jpg
You can see the edge wing near the rear wheels on the RBR is shaped like a converging duct, converging ducts produce jets of air. You can see that the jet of air is aimed right at that little mouse hole on the side of the diffuser.
It's a much smoother design than the Alpine, which looks boxy and sloppy by comparison.
https://i.redd.it/y00rrqra4rp81.jpg
Look at the sparks, they come from the edge wing, right into the diffuser.
https://i.imgur.com/6QHolab.jpeg
You have to wonder where McLaren is aiming theirs.
Finally, only took them 3.5 months.
*downvote away, doesn't change the fact I'm right. :lol:
selvam_e2002
selvam_e2002
-1
Re: Alpine A522
is Alpine going to change floor to meet FIA Flex floor rule change? or we good.
Re: Alpine A522
selvam_e2002 wrote:
20 Jul 2022, 04:56
I don't think anybody know's for sure, with any of the teams. Fry has often said that Alpine made their floor stiffer on purpose but he's not gonna come out and say "oh yeah, we have a retractable plank, so we can get closer to the ground". I don't think they are, based on their ride height has been higher than most, but that an absolute guess. Horner and Wolfe have come and said it will not effect them at all but most pundits don't believe them.
Re: Alpine A522
https://www.auto-motor-und-spor ... nkreich/
Alpine wants to make it as difficult as possible for McLaren and continues its policy of taking small steps. They're getting smaller now, but increasingly efficient, according to the team. The latest step can hardly be seen, but should bring a decent lap time. The underbody was modified at the edges and one of the four baffles in the front part of the floor got a new shape. New parts are also to be added in Hungary. This is the path that Mercedes has now taken.
stan_french
stan_french
Re: Alpine A522
diffuser wrote:
22 Jul 2022, 06:10
I honestly hope those updates do get smaller, they've really milked this car upgrades wise, but it seems alonso is a little more dubious of its effect on next year's car, or at least he wants the switch to happen asap.
I'm curious to see what the effect on next year this will have.
Re: Alpine A522
Re: Alpine A522
Sensibly different floor here. The changes kinda mix Alpine's usual design there, with the RB one...
Re: Alpine A522
Alpine removed the first fence (1) & lowered/flattened that portion of the floor, & changed the angle of the second fence (2).
& other pictures suggest that Alpine added a new fence behind fence 2 but I'm not sure.
That area now looks like one of the older RB floors, but mixed with Alpine features.
Re: Alpine A522
Re: Alpine A522
*unless the new fence is an RB-style ice skate ?
Re: Alpine A522
If you thought those wings coming up off the front of the floor were straight...think again. They have a curve of a hockey stick.
Re: Alpine A522
Indeed, it seems the A522 floor now has an RB-style ice skate... unless I'm seeing things..
RB:
Re: Alpine A522
Blackout wrote:
24 Jul 2022, 19:29
https://pbs.twimg.com/media/FYcrTPBXgAI ... name=large
https://pbs.twimg.com/media/FYcspu3WAAY ... ame=medium
I had my suspicions...not sure how many pictures I looked through yesterday. Great find.
Also when I looked at the Friday pics, I saw they were testing several different floor side.
Re: Alpine A522
Yes both drivers compared both floor versions in Fp1 and Fp2. And Alpine used aero rake in the sidepods and floor, + flowviz on the floor + aero sensors inside diffuser.... (but only on the older floor spec it seems)
And the A522 boat area of the floor in Austria seems to have 2 dips that weren't there in Melbourne... maybe Alpine added a hump there to squeeze the flow more between 'boat' & inboard fence, & further accelerate it & increase suction there? unless I am seeing things
