2019 Mclaren F1 Team - Renault
Re: 2019 Mclaren F1 Team - Renault
Andres125sx wrote:
12 Oct 2019, 11:58
Juzh wrote:
11 Oct 2019, 17:07
sainz's p7 lap from fp2 - 1.29.051
https://streamable.com/9538k
vs verstappen
https://streamable.com/yl7mq
As you can see mclaren holds it's own pretty well against verstappen here up until spoon corner, then gets completely demolished on the back straight. Bad ERS recovery after 130r is a tradition at this point for renault engines. Just look at how much speed sainz loses compared to verstappen at that stage. The sooner they're done with renault, the better for them. I don't think car itself is too draggy, since speed on the main straight is almost identical.
Wow thanks for the videos and analysis =D> . Yes both cars are perfectly matched up to spoon, and after 130R top speed before hitting brakes is 303km/h for RBR vs 288 for McLaren :o
Aerodinamically I think we can safely say RBR is some step forward, so PUs power can be argued, maybe Renault is providing a bit more peak power wich makes up the deficit of running more wing, but we can´t argue Renault is lacking some ERS recovery with that difference after 130R when they´ve been perfectly matched the whole lap up to that point
Like I said, I disagree. I think it's inconclusive
Andres125sx
diffuser wrote:
12 Oct 2019, 14:33
Andres125sx wrote:
12 Oct 2019, 11:58
Juzh wrote:
11 Oct 2019, 17:07
vs verstappen
What part? It´sobvious up to spoon they´re matched and before reaching last chicane (so just a straight after including 130R as that´s not a corner nowadays) there´s a big difference, then we can argue about what makes that difference, but I think after 130R it´s obvious McLaren run out of electrical energy. Their speed decreases from 130R making 15km/h deficit compared to RBR when before that their speed had been almost identical all along the lap
Well think about it. Renault seems to make less progress than its competitors, not just their car, but engine wise as well. They were ok at the start of the year but Honda engine is better than Renault's.
A shame as I think McLaren would be closer to the front with a better engine. I hope Renault catches up over the winter.
mwillems
Isn't it possible that the Honda is better at deploying it's energy, but still slower in raw ICE power? It could be that the RB has better aero efficiency that overcomes the engine deficiency.
The engines could be evenly matched, but with different strengths and that the difference is the cars themselves.
I find it hard to believe our car is as good as the RB here, no disrespect to Mclaren. But I don't think that the gap has been closed or that the track suits us that much that it can close the gap to RB for us. Maybe it is that, but I'd need to see more to think it was the case.
-Bandit
Andres125sx wrote:
12 Oct 2019, 14:47
diffuser wrote:
12 Oct 2019, 14:33
Andres125sx wrote:
12 Oct 2019, 11:58
Read my reply to him above or the previous page. and below now.
godlameroso wrote:
12 Oct 2019, 15:28
Like I said:
Sainz actually goes in to turns 13 and 14 ahead(1:04) but comes out behind Max(1:09). Max carries 10 KPH more speed thru the corner. Max also gets on the throttle a fraction earlier. Sainz never does recover more than half of that 10KPH before 15. It only appears to, since Max hits 15 earlier and has his speed drop off earlier.
You could argue that the Renault out accelerates the Honda in the uphill battle out of turn 14 down into 15 because Sainz's speed is getting closer and closer to Max's, having started with a 10KPH deficit.
It's obvious Both PUs are struggling to acheive the same top speed they get going downhill past the finished line and into turn 1. We would need to see the back of the car to see if the flashing light turns on to see if they're out of electrical power. I would not be surprised if both cars run out of electrical power for a few seconds and then it comes back on. Since they're both at full throttle the turbo is at max electrical generation. The acceleration looks uneven at times. Looks like it slows then returns to the previous rate. that could be a 1000 things though.
diffuser wrote:
12 Oct 2019, 15:58
godlameroso wrote:
12 Oct 2019, 15:28
There is only one DRS zone, plus downhill, without DRS on the back straight the car's drag is there to see. Terminal drag may be higher on the McLaren vs RB.
Perhaps reducing rake at speed helps in this regard, and McLaren has less dynamic rake than the top teams.
godlameroso wrote:
12 Oct 2019, 16:28
diffuser wrote:
12 Oct 2019, 15:58
godlameroso wrote:
12 Oct 2019, 15:28
Finally, you had me worried for a second ... I thought I had lost you to the world of BS!
_cerber1
275
The third sector of Lando was better than that of Carlos, you need to find his video and see what is there with speed. In general, speed in training is not indicative
_cerber1 wrote:
12 Oct 2019, 16:47
Considering they'll still have qualifying by the looks of it, and a good day to optimize the cars things should even out. The circuit will be incredibly green, and will ramp up tremendously, timing will be crucial. Sometimes the circuit peaks then falls off, sometimes it keeps getting better as more laps are put on it. Qualifying will be quite busy and no one will bother running anything but soft tires, the race will be a different matter. With a lot of downforce on your car you will have less sliding, but higher cornering speeds, so finding the compromise for the race will be tricky, as too much one way or the other can hurt you. Benefits of having a lot of downforce, flexibility with tire wear, ability to follow other cars, hurts you on straights. So for defense on straights having a little less downforce is better, particularly since slipstream is stronger now.
You'd need a tire advantage for it to work though, so lucking into a safety or virtual safety car? Unlikely as it usually only happens on lap one. After a few laps the pace is settled and only in late race do we see people dicing it out, unless we see alternate strategies being played out.
Tire wear is an issue around here, with noticeable degradation after 20 or so laps on even the hardest tire. A two stopper is possible for some, McLaren has traditionally been kind on its tires so they could benefit from a one stop if the pace is there.
With 53 laps management will be key in order to make the one stop work. McLaren seems to have very decent long run pace, and with tire wear they may have an edge over the others.
RonDennis
RonDennis
Should be a easy P7 and P8 without any problems.
SmallSoldier
SmallSoldier
486
And that’s P7 and P8... Great showing by Mclaren and awesome drive by both Carlos and Lando... 1.2 seconds from pole is definitely an improvement!
Nice setup for the car and should work well in the race... Time to try and get some good points... With Renault starting in the back of the midfield, this is a great opportunity to build a comfortable lead in the WDC.
_cerber1
275
P7 and P8 =D> =D> =D>
Oh the irony..... McLaren was faster that RBR in S3 in Quali! Looks like my analysis of the S3 was right!
