Exhaust Blown Floor - Forward Exhaust Exit
240
Re: Exhaust Blown Floor - Forward Exhaust Exit
shelly wrote:
So: on the side of the car between the wheels in the reference frame of the car there is a strong fluid flow, which is the one deflecting exhausts and dust backwards in that reference.
Ok
I See, not incorrect, but it doesn't really provide evidence. Whether it is strong is disputable. The front wheel wake is very weak IMO. You'll find low speeds in that region; which the FEE aleviates.
MIKEY_!
How legal would a kind of slit exhaust (like that on the mclaren during testing) be when mounted on the splitter. What are the rules regarding holes on the top of the splitter???
imightbewrong
imightbewrong
From the horse's mouth:
[youtube]http://www.youtube.com/watch?v=PDWFaRVQ ... r_embedded[/youtube]
CMSMJ1
CMSMJ1
Renault running rear exit system on Heidfeld's car today....
IMPERATOR REX ANGLORUM
DumHed wrote:having read this thread from the beginning, after hearing people talking about how the FEE works, I've finally signed up on F1Technical - because it's getting a bit stupid!
Why is everyone arguing in absolutes?
Obviously in at least some conditions, some of the exhaust will go under the floor and through the diffuser. (High yaw, low exhaust flow, crosswinds?)
Will the small amount of exhaust, after travelling the distance to the diffuser, add any meaningful mass flow or drop of temperature and therefore volume / pressure through the diffuser?
I see no possibility of the majority of the exhaust being sucked under the floor and into the diffuser, as there would be no benefit. Normally the floor is designed to keep low pressure high velocity air underneath - sucking minimal air in from the sides.
To get the diffuser to suck exhaust in from the sides would mean a massive amount of ambient air coming in with it, greatly reducing the effectiveness of the floor and diffuser.
In my opinion, the FEE is creating downforce directly on the front corner of the floor, by blowing very high velocity gas under the small aerofoil section there, and is also creating a virtual skirt by pushing air away from the side of the floor - to prevent it from being sucked in and harming floor / diffuser efficiency.
The exhaust volume and velocity, especially with the extra "blowing" engine mapping techniques carries a lot of energy, and with the near 90° exits, will blow quite wide until high car speeds.
Have a look at the exhaust of a car running on a dyno. Even with a 300-400hp turbo engine and a 75-100mm diameter exhaust exit, quite a strong jet can be seen and felt - usually very visible due to the light fuel smoke caused by rich air fuel ratios.
Said it better than me.
imightbewrong wrote:From the horse's mouth:
MY GOD!! HOLY JESUS!! AMEN!! HALLELUJAH BORTHER Imightbewrong!! Preach it!!
=D> =D> =D> =D>
Thread is concluded...
Just remember guys nobody is a loser, we had a constructive discussion, we all listened to each other, we learned many things, we agreed, we disagreed that's a forum. You know, opposing theories cause us to do more research on both sides - no reason to come back with a fury now :wink: :wink:
Anyway, I am just belated that we are rewarded with a direct answer -
I am sure Peter was reading this this site! =D> =D>
ringo wrote:This is why the F1 car loses downforce when following another car. The speed of the air behind the leading car is higher than still air. This means that the following car will pass through the air at a slower rate. It's all relative.
So, nothing to do with the vertical component of the flow coming off the leading car then?
240
Diffuser diffuser.
The diffuser is not always the end game for everything blown. :wink:
Now this thread is really good treasure trove of discussion and proof of CFD tests outside of a super computer equiped F1 team or lab.
This conclusion was made months before there was any input from the Team.
It was spot on as well.
What Alison says is no suprise, and this may be why it seemed like i was being arrogant. If you do a sound and measured experiment and you get your results, and then you go and witness in the field real time observations that are in line with yours, you may come across as arrogant if someone with no evidence but their words tells you otherwise. You simply cannot discard what you observed or back down because you can't call upon the big shot inside links.
The speed and the energy is important. The further the exhuast travels the more speed and heat energy it loses. This was the elephant in the room.
For maximum energy to whatever part of the car, the exhaust exit has to be located there for greatest influence.
2.5m down stream isn't going to help much, even it's going to the diffuser.
Blunty:
Put high energy where you want the greatest effect. Simples
marekk
marekk
ringo wrote:Diffuser diffuser.
Blunty:
Ringo, can you please post once more your CFD showing low pressure area generated by airfoil-shaped part of the floor's leading edge in front of exhaust pipe to help us better understand James ?
Maybe with some geometry details of affected parts of your modell (or just used airfoils) ? With this, we could try to calculate real downforce numbers.
Pierce89
Blunty:
TBH It seems to me that uor theory is not what Allison said. He said they DO BLOW THE FLOOR. This thread claimed all the exhaust went out along the sides of the car. Allison said the the R31 blows the "wing profile" at the LEADING EDGE of the floor. That's different from what has been said in this thread.
240
you,re not reading the whole thread then. :wink:
all littered throughout the thread:
240
ringo wrote:Where do you get your theory from? which reference?
The exhuast speed is 220m/s it's not 38m/s. Usain Bolt can run over 30m/s.
As to the flow, no human being can simply suggest where it's going. You need years of experience, and even then Willem Toet the aerodynamicist declined to make a guess.
but it's a good thing you bring up this picture.
If the air is going down 90 degrees, then why is there a gurney at the edge of the floor?
We always see these gurney on down-force generating devices and especially when exhaust flow is involved.
Why put the gurney if the gases never get there?
etc. etc. It's all there pierce.
hardingfv32
hardingfv32
The body work in front of the exhaust outlet does not look like much of a wing. Is this "wing's" axis more inline with the exhaust outlet than the chassis axis?
Why does it look like the leading edge of the "wing" in very close to the top of the exhaust outlet? Is this the correct way to blow a wing?
Brian
shelly
shelly
136
I agree with Pierce. Allison seems to suggest that the exhausts follow a path even narrower than waht I expected, getting trapped into the vortex system of the barge boards
twitter: @armchair_aero
hardingfv32
hardingfv32
Would this "blown wing" be better for car balance being during different exhaust flow levels, being that it is located close to the center of the chassis?
Brian
