Martin Whitmarsh is in agreement with Luca:
http://uk.reuters.com/article/2011/05/0 ... Y420110506
This has also been discussed a little here:
viewtopic.php?f=1&t=9970
Personally I think the new regs are a disaster and I wouldn't mind seeing a drastic overhaul in F1 in terms of design freedom, like the possibility of a different chassis shape, as well as opening up engine development, bringing F1 closer to it's roots. Will a team-owned F1 create this possibility?
I couldn't pinpoint it, but someone said elsewhere on the forum that as things currently stand the teams basically set the regs anyway. Along these lines, supposedly ground effects were ruled out for 2013 (
http://www.autosport.com/news/report.php/id/91304) because they would be difficult to regulate in terms of monitoring performance- apparently the decision was made by the 'overtaking working group' which is composed of team members, so unless they are acting under the influence of Bernie or some outside group, I guess a change to team ownership wouldn't shake things up too drastically.
So if that is the case then a change to team ownership will just keep the money "in the family" which isn't so bad.
