Great video, thanks Jackhammer. I think they should pursue this, it's a long time coming.
gerhard wrote:Actually, I think the main concern would be how fast can the driver get out of the car in an emergency situation. Certainly it would NOT involve seat ejection!
The cars would certainly look good with such a thing, but I think a lot of the sport romanticism would be lost.
richard_leeds wrote:Two issues:
Could be strong enough to resist impact from a flying tyre or rolling.
Could it slow down evacuation, or even trap a driver in the car after a crash.
I think fighter aircraft canopies would be a good place to start looking for precedents on both issues.
ps - opaque canopies would be terrible, we need to see the diver.
I wonder if they could have open faced helmets if the canopies are mandated. Rally car style, so you could see the drivers faces through the canopy and/or with dash mounted cameras. Would also help a ton with understanding drivers' radio chatter, if you could see their lips moving. Although, closed roof LMP car drivers still wear closed helmets.
When was the last time you saw an F1 driver's eyeballs? Could be a great visual; good draw for the sport, marketing etc...
Visualize something like this:
^Would be epic, IMO, to see this on track. The emotion of victory & defeat on display, seeing familiar faces squashed as they go through those 3 G corners...
Speaking of marketing, the canopies could make the cars look more high tech, IMO, in an age where the sport is becoming more and more of a spec series.
Safety wise I would want to improve the onboard fire extinguishing apparati and add a hatch or removable section of floor under the seat in case the car is flipped.
Speaking of explosive bolts, I wonder how they could be used to improve driver accessibility post-crash. If the monocoque is split up into more of a frame-like design, joined together with explosive fasteners, the stewards, driver or race control could select which bolts to detonate based on the car's condition and orientation. Then the panels/frame section could essentially be pulled apart on site by stewards or pushed out by the driver. Maybe embedded pneumatic pistons at the joint as well, to "pop" the joint apart after the bolt blows.
