LCD Screens
panda
panda
LCD Screens
Who would be the supplier for LCD Screens for the Acura LMP car and the Aston Marton Racing one Car? Could anyone direct me to that manufacturing?
Just curious. Thanks
spacer
spacer
Re: LCD Screens
You mean the dashboards on the steering wheel? Do a search for the big data-aquisition guys, basically all of them have some sort of lcd-type dashboard.
Try a google searh on: AIM, Magnetti Marelli, Bosch, MTA, I believe even Cosworth has an autosport-electronics line (PI) :).
panda
panda
Re: LCD Screens
Looking for the ones mounted on the steering wheel specifically on the Aston Martin one and the Acura LMP cars.
N12ck
Re: LCD Screens
Would this not be better placed in the 'other racing series' thread, or 'off topic' thread, as its not relevant to f1 really
Budding F1 Engineer
flynfrog
Re: LCD Screens
It was probably custom made. You can buy a raw LCD and make your own if you wish.
hypeboy
hypeboy
Re: LCD Screens
flynfrog is correct, absolutely it's custom made. most car lcds were made customized. the manufacturer only provides the car and parts, they can't change the architecture of the car. :)
Reason: Removed Spam Sig.
SpookTheHamster
SpookTheHamster
Re: LCD Screens
The one on the Aston is made by Cosworth, the Acura is probably MESL, like all the rest of their electronics
ESPImperium
ESPImperium
64
Re: LCD Screens
It will either be Cosworth or Xap (http://www.xap.fr/) France most probably. However it could be a small outfit that is off the usual radar, or a simple in house operation.
Needles in heystacks this could be.
The MES display is used in F1 and in LMS by Peugoet as their drivers are most comfortable with that display. CART/IRL use a outdated Cosworth display, but are moving over to a new display for the 2012 car. Superleague Formula use Cosworth, WSR and GP2/GP3 use a Xap display that is pretty much the same accross the 3 formule, however the new WSR 2012 car has a wheel and display with 2 new buttons i belive, one for DRS and one that is currently blank that could eventually be used for KERS id guess.
There is a move from the GP2 guys for the GP2 wheel to have the MES display and a couple of settings they can tinker with thru the race as this would give them less to learn coming into a F1 car. However this will probably come in in the next generation GP2 car in 2013/2014 after this one has had its 3 year cycle consumed.
