hello every body,
Fist what is cfd?
1-CFD stands for Computational Fluid Dynamics.
2-CFD uses computers to represent (or model) the flow of any fluid around a body or inside it in cas eof internal flow or it can model the heat
distibution.
It start with an equation which define the system Like streamline equation in case of air flow about any solid body for example and we need to solve this equation over defined domain which we call computational doamin .
the next step is to see what solution technic we have to use to solve the equation depend on the classification of the equation.
Then time for meshing has come we creat a grid over the computational domain and good mesh mean more acurate solution so then solution is try to solve the points of the grid. and try to reach Convergence to get an accurate solution.
this steps done by the software all you have to do is gove the input and analyze the output and try to enhance your design.
FAE is a soultion technic used to solve the grid point and it use in case of complex geomerty i think this is what i know about FEA method.
I think that's good for today.
BYeBYe BYe
