some of you may be aware that BBC radio has a programme called Radio5 Live
amongst other things they do an excellent live broadcast on each F1 practise session , and this is used as the commentary to the BBC TV satellite broadcast of these sessions
normally , as well as an excellent commentator , they have an ex F1 driver to comment , anthony davison at this time , but as he is racing this weekend they roped in jackie ; personally I agree with some of what jackie says , but far from all ...apart from anything else you must admit that he has been there , done it , and SURVIVED IT , in itself a feat for his generation
not surprisingly the subject of massa/hamilton came up , and there was a lengthy discussion on the matter ; the first thing he said was ...no overtaking , no F1 , with which I find no argument ; however he then went on to say that the great drivers had relatively few accidents and he didn't put drivers like senna and schumacher in the top rank for that reason , but jim clark and alain prost were ....he added that he thought vettel the best all round driver for his age that he had ever seen
he said that some drivers were difficult to overtake because they were unpredictable in their responses ; when asked for examples he said that drivers like jack brabham and jo bonnier were like that ; so you didn't put yourself in the position where they could collide with you and opined that hamilton didn't do that hence the latest massa collision
here is where I disagree ; I am sick of hearing about the racing line ...for me the racing line is the fastest way around the track ...if use of that line is not in dispute
I believe that the conventions of overtaking need to be revised ...no good complaining about inconsistent decisions from the stewards if there are no clear guidelines for them to follow
so what should those guidelines be ? I believe the following
clearly overtaking can take place on the straight or in the corners , and guidelines are needed for both
ON THE STRAIGHT
if a driver is attempting to overtake you he must be allowed a cars width even if he doesn't have an overlap ...if he has a run on you , no blocking or intimidation : is what schumacher did to reubens last year , or vettel did to button this year acceptable ? not to me it is not ...making a move doesn't extend to running your opponent off the track
ON A CORNER
different rules needed for inside and outside overtakes
inside ;if the overtaking driver is able to get his front axle ahead of your rear axle with all his wheels on the track you must give him a car's width ; you don't wish to do that , going off line ? then you should have driven defensively to stop him getting there , and accept the slowing effect ; that may give him a chance around the outside but hard luck , he is clearly quicker than you
outside ; if a driver tries to overtake you on the outside you are entitled to take your normal line without going extra wide on the exit ..up to the overtaker to avoid the accident
Monaco this years provides a few examples
schumacher dives down the inside of hamilton at the hairpin ...hamilton gives him room , no accident
hamilton dives down the inside of massa at the same corner ...massa won't give him room ...collision
hamilton dives down the inside of schumacher at st devote ...schumacher gives him room ...no accident
hamilton dives down the inside of maldonado at st devote , ...maldonado won't give him room ...collision
if you feel this thread worthy of comment , please no fanboyism, it isn't pointed at any particular team or driver and if hamilton and massa keep coming up then they would this year , wouldn't they !
the point for me is that I have had enough of this hamilton/massa type business , great for the gutter press , but I want to see these guys RACING ; I understand where jackie is coming from , some of the things we have seen the last couple of years would have resulted in people getting killed in his times , and you can hardly expect him to forget that , especially in the light of events in recent weeks
