The new front wing test for the front wing in 2012 is for 100kg to be applied to one side/endplate. The wing cannot flex more than 10mm.
Looks like the flexing wings are gone!!
100kg on both ends at the same time, with a max movement of 20mm.Ganxxta wrote:And what are the specs for the Test in 2011 in relation?
Lets assume that this number is more or less correct, then 100kg(+-) per side is the actual force being applied to the wing anyway, if my thinking is correct that all of it is split up to left and right...Ian P. wrote:... then the front wing is contributing about 500 Lb or roughly 200 to 250 kg.
Maximum downforce is more likely the quad of the weight than the double.Ian P. wrote: And total downforce is about double the weight of the car, then the front wing is contributing about 500 Lb or roughly 200 to 250 kg.
Yes but all of the 500-600kg isn't pressing down on the endplates.Lurk wrote:Maximum downforce is more likely the quad of the weight than the double.Ian P. wrote: And total downforce is about double the weight of the car, then the front wing is contributing about 500 Lb or roughly 200 to 250 kg.
2003 lola champcar generated 4376 lbs of DF at 180mph (1984kg at 290km/h, source: mulsanne's corner). Imagine what a modern f1 car can produce...
500 to 600kg on the front wing alone, FIA test is far from that.
If they can't find any other way to properly enforce it then they should run every single cars front wing in a wind tunnel to generate proper load on it and measure it fully. If that means front wings are homologated then so be it.xpensive wrote:So the FIA still haven't got it, have they? They need to add the horizontal load from aerodynamic drag to get the true vertical deflection from an anisotropic structure as a modern carbonfibre front wing, this is the obvious "secret".
