Aerodynamic implications of nose inlets
horse
OK, so here is some maths.
According to Schlichting for high Reynolds number the boundary layer is approximately 5 * Re ^ (-1/2).
So lets choose the chassis height as a length scale, say 25cm and a velocity of about 200kph or 50 m/s.
Then the Reynolds number is about 1250000, so it's pretty high.
The boundary layer thickness is then going to be approximately 4.5mm.
That duct really isn't much deeper than that.
Adrian Newby wrote:I proposed that Newey was trying to peel off any turbulent air in that area, and then use that low-energy air to cool the KERS.
Yeah, I think the above is the calculation for laminar boundary layer. I just don't think that there will be a great deal of air induced by such an intake - perhaps they don't need much?
Adrian Newby
Adrian Newby
-1
Re: Red Bull RB8 Renault
horse wrote:OK, so here is some maths.
That is my thinking, that they don't need much, although, judging by KERS overheating last year, maybe a tad more than they calculated!
volarchico
volarchico
Why would we use the nose height as the length scale? The length scale should be the distance downstream from the start of the boundary layer. I know Wikipedia isn't authoritative, but my aerodynamics textbooks are at home buried away on the shelves somewhere. From my memory, the basic equations and principles presented here are correct:
http://en.wikipedia.org/wiki/Boundary-layer_thickness
Using turbulent boundary layer equation, and 50 m/s (180 kph), and a length scale from the tip of the nose to an approximate location of the inlet (~750 mm), the 99% thickness is 15 mm.
But keep in mind the turbulent boundary layer velocity profile is much steeper compared to a laminar one. So even scooping out the bottom 50% of a turbulent boundary layer is actually taking a good bit of air.
EDIT: Image of profile:
Adrian Newby
Adrian Newby
-1
I agree with you on the length scale.
It seems that Newey made the lower duct as wide as possible to catch as much of the turbulent layer as he could, then calculated the height that would be needed for getting the amount of air he required for his purpose (KERS cooling, in my opinion).
kilcoo316
kilcoo316
21
That ducting wouldn't need to go very far; there will be a pretty adverse pressure gradient in a small duct that ingests only a boundary layer from outside.
Upon entering the narrow slit, the two expanding viscous sublayers (from upper and lower surfaces) will damp out the largest of the outer layer eddies somewhat, but you'll end up with further (form) pressure losses from both sides and a rapidly decreasing u(z). Indeed, which would in fact no longer exist if the flow becomes fully developed, it would be u(δ) instead which will decrease the further the flow travels down the duct.
Obviously, this adverse pressure gradient will perturb back upstream and affect the flow rate coming in (and the boundary layer under the nose/monocoque).
What do the rules say regarding ducting exits? Is it aft of the driver?
It may be that this slit simply bleeds off the boundary layer prior to the splitter (to reduce interference 'drag' effects - not the drag itself, thats incidental in the grand scheme) and cools the driver's backside!
240
The boundary layer discussion is not really relevant.
We are looking at a air crashing into a wall, not flowing along a surface.
The air will simply stagnate in that damn, you get some circulation going, a high pressure bubble if you will and less turbulent more streamlined flow will flow over it.
This will happen at high speeds.
This is cheap and dirty downforce from that high pressure static zone.
What is interesting about that part of the nosecone is that it is convex. Its worth investigating i think.
Adrian Newby
Adrian Newby
-1
ringo wrote:The boundary layer discussion is not really relevant.
The boundary layer discussion is about the lower intake.
The upper intake is not an air dam. If anything, it is the opposite of that.
240
On the lower surface, Bernoulli cannot be used in it's simple form. The equations will change because of gravitation and pressure potential.
The surface is curved and the air is underneath the surface.
What is the opposite of an air damn?
Adrian Newby
Adrian Newby
-1
ringo wrote:On the lower surface, Bernoulli cannot be used in it's simple form. The equations will change because of gravitation and pressure potential.
There are many, many things going on under the nose, behind the front wing, between spinning tires, etc.
The opposite of an air dam, which builds up a high pressure bubble, is to allow pressure to flow through an intake (in this case, the one in the hump on the nose).
bhall
bhall
244
Ringo wrote:What is the opposite of an air damn?
Adrian Newby wrote:The opposite of an air dam, which builds up a high pressure bubble, is to allow pressure to flow through an intake (in this case, the one in the hump on the nose).
Otherwise known as a vent?
(I'm just reminded of the joke in "Beavis and Butthead Do America" - oh, yes - where Beavis asks a Hoover Dam tour guide, "Is this a god damn?")
(Made the off-topic a tad more discreet.)
Adrian Newby
Adrian Newby
-1
Yes, exactly, a vent. Newey is venting that high pressure air into the chassis to "cool the driver" and then exiting it through the cockpit opening.
shelly
shelly
136
I think boundary layer idea could aplly to bot tha lower an upper opening. Concave surface gives a steeper pressure gradient (basic theory of flow acceleartin on covex surface and decelerating on concave)
twitter: @armchair_aero
Adrian Newby
Adrian Newby
-1
shelly wrote:I think boundary layer idea could aplly to bot tha lower an upper opening. Concave surface gives a steeper pressure gradient (basic theory of flow acceleartin on covex surface and decelerating on concave)
Yes, that is correct.
Air Dams can have vents. It's just a vent in the air dam.
Adrian Newby
Adrian Newby
-1
hardingfv32 wrote:
Adrian Newby wrote:Yes, exactly, a vent. Newey is venting that high pressure air into the chassis to "cool the driver" and then exiting it through the cockpit opening.
And you think that routing the air around the internal suspension components and the tightly packaged driver causes less drag than say Ferrari's ramp nose? Interesting
Brian
Nope. I think clean, high-energy airflow between the front tires is more important to Adrian Newey than drag on top of the nose, or inside a vent.
Many people here seem to be very hung up on drag, especially the drag of these new humps. F1 cars are very draggy things to begin with. And drag is relatively unimportant on the top of the nose.
