Does anybody know exactly where on the Barcelona track Hamilton stopped?
Is the gradients at the different parts of the track known?
I think we can calculate if he would have been able to make it back to the pits and in what time.
McLaren, in a nutshell."
The fuel rig guy put the rig on, but he had the handle set to drain fuel.
He discovered his mistake and switched it to put fuel in the car. But as a result he didn't put as much fuel in it as he should have.
You have to be able to drive back to the pit-lane and have one litre of fuel left for the FIA to test.
He went across the start-finish line 20 seconds before the chequered flag but if they had sat in the garage for three or four more seconds to get more fuel in, they still would have had time to cross the line and complete another flying lap. Sometimes I don't think McLaren think on their feet."
n smikle wrote:This is all assuming the G7 fuel setting which is the highest power fuel setting so we can trim these down later. Remember in 2011 the front runners were going full power all the way.
Now for the two up hill segents.. he will consume about 0.593km*0.226kg/km = 0.134kg of fuel
Anybody know the density of Mobil1 F1 fuel?
He can coast downhill in neutral at 4000rpm, even turning his engine off for the last 0.75km from turn 13 into the pits.
We have not even considered KERS yet. So, so far it is looking good that Hamilton could possibly have made it into the pits with only 0.134kg of fuel los without using KERS and his engine at 5000 rpm going at a speed of 89 km/hr. It would have taken him about 1 mintue and 20 seconds to reach the pits from after turn 8.
Anybody up for the KERS calculations?
I think the point is that if McLaren had any competance about them, they would have told him from the moment he crossed the line after qualifying. They can monitor fuel amounts and consumption from the pit wall.TheRMVR wrote:n smikle wrote:This is all assuming the G7 fuel setting which is the highest power fuel setting so we can trim these down later. Remember in 2011 the front runners were going full power all the way.
And this can only happen when Hamilton at turn 8 would understand the exact gravity of the issue and act instantly. I think by the time Whitmarsh would've explained him on the radio he would already be at turn 12 cruising at normal inlap speed. McLaren screwed up, nothing more..
