LB-01 - Astracrazy's model
astracrazy
31
so heres how far i've got. Anything i'm doing wrong or any suggestions so far? Ignore the area around the cockpit and sidepod entry there not done at all. I'm asking more about the rear end
N12ck
Re: LB-01
looking good, do your exhaust outlets aim 10 degrees up and out? or are they straight forward?
Budding F1 Engineer
astracrazy
31
Re: LB-01
10 out and up, don't think the render does it justice
N12ck
Re: LB-01
Your diffuser needs more of an aerofoil shape I think
Budding F1 Engineer
astracrazy
31
Re: LB-01
how do you mean?
N12ck
Re: LB-01
astracrazy wrote:how do you mean?
well at the moment its just a straight slant, and the vanes are just straight, rather than curving out (with them being straight makes them almost useless) you need to curve your diffuser, and curve the vanes outwards
Budding F1 Engineer
astracrazy
31
Re: LB-01
ok thanks. I'm stuck trying to end the bodywork around the gearbox, any suggestions?
amouzouris
105
Re: LB-01 - Astracrazy's model
there is also a fillet plugin you can download to make the sharp edges round.... if u want any help with modeling the diffuser send me a pm and ill help u out!
astracrazy
31
i''ve curved the strakes in the diffuser slightly, is this what is meant?
Also i've added a shot of the exhaust exit, hope this shows the angle(s)
RicME85
52
Contact:
Not a bad start.
Why dont you re-shape the gearbox if your finding a solution hard?
CottrellGP
amouzouris wrote:there is also a fillet plugin you can download to make the sharp edges round.... if u want any help with modeling the diffuser send me a pm and ill help u out!
Could you help me with finding and the installation of the program please?
Dan Cottrell
Master Of Innovation!
CottrellGP
RicME85 wrote:http://forums.sketchucation.com/viewtop ... 23&t=20485 - that will do the job
I have a problem though, i have downloaded this but i cant find the download link for the LibFredo6 3.7 or higher
Dan Cottrell
CottrellGP
And now it says im not authorized to download :(
Dan Cottrell
