Autodesk Falcon
astracrazy
31
Autodesk Falcon
Just a quick post, thought it best here for all of us using google sketch and want some form of easy cfd.
http://labs.autodesk.com/utilities/falcon/
trying it at the moment and as far as i'm aware its completly free. You can do 2d and 3d simulaton. Its quiet good! All you need to do is export from sketchup in .stl (plug in easily found on google)
let me know what you think
Jersey Tom
Re: Autodesk Falcon
Good in what manner? That it provides accurate results, or that it makes colorful curvy lines? The latter I can do in Photoshop.
N12ck
Re: Autodesk Falcon
JT is right, the curvy lines are good for people to look at, but the useful bits are the data, drag coefficients etc, also pressure gradients and velocity gradients are particularly useful :D
Budding F1 Engineer
astracrazy
31
Re: Autodesk Falcon
like i said its basic. For me at the moment i'm learning so it helps me see the airflow.
It was just something to show, don't shoot me. Just didn't know if people had seen it
edit: it does give you pressure and velocity. I'm just having a play with it
N12ck
Re: Autodesk Falcon
ahh very good, do you not need to own autodesk first?
Budding F1 Engineer
astracrazy
31
Re: Autodesk Falcon
no just need to sign up. like i said its not the best but worth a look might help slightly
CottrellGP
Re: Autodesk Falcon
What plugin for sketchup?
Dan Cottrell
Master Of Innovation!
Jersey Tom
Re: Autodesk Falcon
astracrazy wrote:like i said its basic. For me at the moment i'm learning so it helps me see the airflow.
I'm just saying that you might not necessarily know if it's giving you a true result. In which case if you're using it as a learning tool, you don't want to learn the wrong thing.
Greg Locock
233
Re: Autodesk Falcon
Off the top of my head here's the start of a battery of test cases, of course any aero textbook probably has more worked examples.
Flow through a venturi. correlate with http://hdl.handle.net/2060/19930083792
Any airfoil for which you have Cl and Cd plots, vs alpha
a sphere
a rotating sphere
astracrazy
31
Re: Autodesk Falcon
CottrellGP wrote:What plugin for sketchup?
no you export your model in .stl (which you need a plugin for) then import it into this
tomislavp4
Re: Autodesk Falcon
Tried it. It´s better then nothing I guess but no good for serious stuff. As far as I can tell, you can´t specify rotating bodies nor a rolling floor. There are no mesh-control settings either.
I think this is made for car-designers, so they can assess their early designs without bringing in the aero-guys. :)
astracrazy
31
Re: Autodesk Falcon
its clearly not as good as paid software, but for free and easy to use its a start.
Greg Locock
233
Re: Autodesk Falcon
The old workaround for lack of a moving floor is to use two mirror images. Doesn't get around the rotating wheel problem.
astracrazy
31
Re: Autodesk Falcon
two mirror images?
