first of all :
pull or push the underlaying aspect of it is clearly :
You use a rod to transmit the vertical wheel force into the chasis .You could mount the sping/damper units directly to the upright or the wishbones ,or have a wishbone doubling up as a rocker as well but Formula 1 has decided decades ago it makes sense to move the springs and dampers away from the airstream between tubenginegearbox and tyre as an aero benefit.
Additionally the rod arrangement will allow you to design rising or falling rate spring and Damper rates by arranging of mounting points of the rockers a very useful thing in the light of aerodownforce rising steeply with speed.
Furthermore you can put favourable leverage on damper or spring movement -very important in the light of miniscule wheel vertical movement....and dampers in need of several mm of travel to build up force!
The downside of it all : starting from the hub your bearing or svivel count is very high
ne on the hub one on the rocker ,the rocker itself to the chassis plus the two svivels at each end of the damper ...Inevitably there is a lot of mass but installation stiffness issues as well -as each and every bearing will add to the total give or impreciseness of the system possibly multiplying factors leading to a meriad of other troubles -bind ,slag ,stick slip,vibration -you name it.
The pullrod has a undeniable advantage : the maximum loads will arise always in bump situations and the pullrod is under tension in these conditons -so usually the parts are loaded in a preferable mode-tension when overload conditons may occur. A pushrod will suffer buckling loads in these conditons -so it needs a ALOT more safety margin and therefore needs to be thicker.
The up or downwards angling ios not really a characteristic of the systems to tell them apart .
