MGU-H (TERS)
gitane
gitane
MGU-H (TERS)
Looking at 2014 engine I see that the MGU-H is driven from the turbo. This may account for the size of the turbo on the Renault engine. I have heard also that the MGU-H may also be used as a motor to spin the turbo. Anyone else heard this?
Any other details or links on the subject?
Laissez les bon temps rtoulez! G
riff_raff
riff_raff
Re: MGU-H (TERS)
Using the turbo spool to capture/return energy to the propulsion system is less complex and lighter weight than other approaches. The turbo spool is de-coupled from the drivetrain, so there are fewer control and dynamic stress issues. Plus the turbo spool operates at very high speeds, which means the mass of the motor/generator is much smaller than previous electric KERS devices that were mechanically coupled to the engine via gear train.
A: Start with a large one!"
autogyro
autogyro
Re: MGU-H (TERS)
The original KERS system MGU-K is still fitted however.
To be specific the motor /generator for the MGU-K is connected to the crankshaft with a set of gears.
