MateusV8 wrote:As long as I know, magnesium was introduced in street cars because, in case of a colision, it shatters, what ends helping on pressure release. I don't know if it is the same purpose on F1.
In the case of a racing wheel, metal has a couple advantages over composite. The primary advantage is that metals have greater elongation characteristics than composites do. Thus, a metal wheel will tend to deform plastically much more before it breaks than a composite wheel would. For example, if the wheel rim were to impact a curb or wall, the metal wheel would bend more readily than the composite wheel, but when the composite wheel rim does fail it abruptly shatters rather than bending. And since a bent metal rim can often still maintain tire inflation pressure, it is much safer than a composite wheel in an impact.
It is also easier to inspect metal wheels for cracks/damage than it is composite wheels.
