knowing that engineers can't 'unlearn' things, and seeing RedBull and others continually trying to seal the diffuser, even after the engine maps were change to disallow it, got me thinking - can they achieve a similar result some other way.
The trick is to get exhaust gases to continue, to seal the diffuser, when you're not on the throttle, correct? Previously, this was done via engine maps - now banned.
Could you get a similar result by playing with the clutch? That is - clutch in & rev like mad - to produce more off throttle gases than normal?
I'm no engineer, but I drive a manual car and I can do this method in that, and I assume it produces more gases, so could some tricky be invoked to bypass the mapping rules to allow this? Would it be viable even? Just a theory.
