F1technical v7
Everything about this website and its content. Here you will find update announcements or requests for feedback. Questions about layout, functionality, content, and your suggestions are welcome.
Steven
Owner
F1technical v7
well... now that it's here, what do you think about the new layout?
Scuderia_Russ
May I be the first to say congratulations. It looks excellent! I love the blue! =D>
"Whether you think you can or can't, either way you are right."
-Henry Ford-
RH1300S
RH1300S
Very nice - clean style 8)
Layout seems fine at first glance
Principessa
I was so lucky to see the première :wink: Already told you Tomba that I love this lay-out more than the previous lay-out.
Again a brilliant job :wink:
manchild
manchild
I'm getting this text on top (above logo and firefox banner)
Warning: mysql_result(): Unable to jump to row 1 on MySQL result index 56 in /opt/www/degrootes/web/www.f1technical.net/forum/db/mysql4.php on line 259
Warning: Cannot modify header information - headers already sent by (output started at /opt/www/degrootes/web/www.f1technical.net/forum/db/mysql4.php:259) in /opt/www/degrootes/web/www.f1technical.net/forum/includes/page_header.php on line 510
Warning: Cannot modify header information - headers already sent by (output started at /opt/www/degrootes/web/www.f1technical.net/forum/db/mysql4.php:259) in /opt/www/degrootes/web/www.f1technical.net/forum/includes/page_header.php on line 512
Warning: Cannot modify header information - headers already sent by (output started at /opt/www/degrootes/web/www.f1technical.net/forum/db/mysql4.php:259) in /opt/www/degrootes/web/www.f1technical.net/forum/includes/page_header.php on line 513
*I'm on XP IE 6
Tomba, I'll send you the screen snapshot by email
Steven
Owner
should be solved right now I think
can you confirm that?
manchild
manchild
It appears only after I log in (instantly). When I surf the site without being logged in everything is ok. :?
West
West
I am getting the same problems w/ the latest IE. I am automatically logged in as well. It appears on every page.
I can't see previous forum posts correctly as well when I make a reply; unless Times Roman is normal.
Bring back wider rear wings, V10s, and tobacco advertisements
manchild
manchild
I got this several times when I tried to log in:
Warning: mysql_connect(): User degrootes has already more than 'max_user_connections' active connections in /opt/www/degrootes/web/www.f1technical.net/forum/db/mysql4.php on line 48
phpBB : Critical Error
Could not connect to the database
Also, since page can't fit horizontally (it is a lot wider than 1024) on old version I used to scroll with horizontal scroll bar but now it won't appear and I only have vertical scroll bar.
As much as I could notice in such short time something is problematic with font too since original font (paragraph settings too) switches to default font (paragraph) formatting. You can see that on snapshots P2 and P3.
manchild
XP SP2, IE 6, 1024X768, 32-bit, 17’’
manchild
manchild
As West wrote the font switches to default font which is Times New Roman 12
Another bug (or isn't it) - In the left blue meny under Interactive links... when I'm in forum "forum" font is bigger than the rest of link fonts?
Guest
Guest
manchild here as Guest
I'm posting this one on purpose as Guest because site works and looks perfect untill I log in. After logging in it goes crazy in many levels...
Post previev as Guest looks good too.
Guest
Guest
manchild here as Guest again
Unfortunately, topic review is in default font without usual colors & shading (gray bcgrnd and black Times New Roman 12 font).
Same goes for posting.php which looks identically as when I'm logged in (default formatting and Times New Roman 12 font with some elements of the page missing/some images.
Guest
Guest
Those missing images on after posting page have strange url (at least to me) for example logo has this url http:///images/logo8r.gif while good url for logo is http://www.f1technical.net/images/logo8r.gif
Same goes for most of the other images on that page.
manchild
manchild
Some of the fonts that remain Arial or Verdana (whatever) after logging in appear in various increased sizes.
I hope that there is no need to say that I'm writing all this in order to make things work, hopefully with observations form other visitors...
manchild
manchild
These two links also have bad url just like images on that page (http:///...)
Click Here to view your message
Click Here to return to the forum
