Is it a common thing in F1 in terms of the regulations or maybe the shape of aerodynamic parts?
Interesting, cool to hear that are aware of it when you are working.Pup wrote:I've been told that F1 prefers ellipses.![]()
I'd assume that if you could find golden sections on the cars that it would be entirely coincidental, or perhaps evidence of the inherent beauty of nature.
I'm an architect and I tend to use golden section proportions when I can. But I'll let you in on a bit if a secret: most of it is bs. It's pretty easy to find or fudge golden section proportions onto any existing design, provided there's enough stuff to draw extension lines to.
Most classical architecture used direct geometric proportions, and most of what we define as classical orders never really existed in the architecture they claim to represent. That's to say, I'm a fan of the golden section, but it isn't the end-all of beauty.
I certainly wouldn't. I'd bet it would have a deep seated mathematical reason why it was so.Callum wrote:I wouldn't have thought so. The complete overriding aspect is performance. If the shape of parts decided by supercomputer has the golden ratio I would believe it only to be coincidental.
ROFLPup wrote:I've been told that F1 prefers ellipses.![]()
Heh, I'm really glad you said that – here was me sat here thinking "wow, some of the sections drawn there are pretty arbitrary"... Take for example the section drawn between front of doors, mid doors and wheel well. I was thinking "why wouldn't you draw that between front of doors, mid of doors, and rear of doors (and just happen to use a different point on the diagonal of the middle doors). Similarly, notice that the section for the size of the wheel arch and the overhang at the rear uses an entire different point on the wheel arch to the above section, despite corresponding to the front of the rear wheel arch.Pup wrote:I'm an architect and I tend to use golden section proportions when I can. But I'll let you in on a bit if a secret: most of it is bs. It's pretty easy to find or fudge golden section proportions onto any existing design, provided there's enough stuff to draw extension lines to.
