BMW BT 52 Turbo F1 car revived.
Hail22
144
I didn't know where to post this...however seeing as this is the General Formula 1 section I thought I share this video I just saw of the BMW BT 52 Turbo being revived! I was quite chuffed to see it breathing back into life once more!
Anyways enjoy!
Gilles Villeneuve
Sombrero
Sombrero
126
Re: BMW BT 52 Turbo F1 car revived.
Virtually... alive !
FW17
185
Any reason why the intercooler is lot smaller than the radiator?
And what material is it that glows purple?
Holm86
261
WilliamsF1 wrote:Any reason why the intercooler is lot smaller than the radiator??
Different regulations. Engines werent limited in numbers you could run during a season. You could just add more boost to compensate for lower density of the air.
Plus fuel wasnt limited either. So om pretty sure engines was run rich to cool the engines with petrol.
And they still made a ton of power. So not much need in increasing the efficiency of the engines. You could just add more fuel and air.
timbo
timbo
113
Holm86 wrote:Plus fuel wasnt limited either. So om pretty sure engines was run rich to cool the engines with petrol.
They were, indeed.
So much that Brabham was famously producing visible smoke on the qualifying runs!
WhiteBlue
92
Hail22 wrote:I didn't know where to post this...however seeing as this is the General Formula 1 section I thought I share this video I just saw of the BMW BT 52 Turbo being revived! I was quite chuffed to see it breathing back into life once more!
Anyways enjoy!
http://www.youtube.com/watch?v=sa96-rneVLI
Great stuff!!! I loved to see Surer and Emmo get back into this tin foil soap box chassis and chase it around with manual gear change. Must have been exiting when they raced it, and bloody dangerous by the looks of it. Those guys had brass balls.
xpensive
xpensive
214
"Tin foil soap box chassis", perhaps you have your BT-designations confused WB?
lotus7
lotus7
WhiteBlue wrote: I loved to see Surer and Emmo
Emmo ?
While we are at it - BMW BT52 ?
WhiteBlue
92
xpensive wrote:"Tin foil soap box chassis", perhaps you have your BT-designations confused WB?
If you look at the thing from a modern perspective it provides less protection then a soap box would on a comparable speed level.
Emmo ?
Unless I'm very mistaken it was Emmerson Fittipaldi driving the thing up the hill in Goodwood this summer.
rjsa
rjsa
51
Piquet
GitanesBlondes
26
Emmo ?
Nelson drove the Brabham at Goodwood.
Emerson was driving the Lotus 72 at Goodwood.
"I don't want to make friends with anybody. I don't give a sh*t for fame. I just want to win." -Nelson Piquet
thisisatest
thisisatest
there appears to be so little negative camber up front that it could very well lean positive. i realise back then the suspension geometry wasnt bass ackwards like it is now, but even the renault behind it near the end of the video has SOME negative camber.
whats up with that? is that how this car was generally set up? or is it only in this one instance?
WhiteBlue
92
rjsa wrote:Piquet
Oops, my bad!!
Hail22
144
Just so no one gets confused :)
[youtube]http://www.youtube.com/watch?v=xucIZ4tC2Ys[/youtube]
Gilles Villeneuve
