It´s Nickel and Titanium.
(text not written by me.)
No the opposite, when heated it reverts back to it´s original state.tim|away wrote:Does it revert back to state A if cooled down?
Nickel titanium, also known as nitinol, is a metal alloy of nickel and titanium, where the two elements are present in roughly equal atomic percentages.
Nitinol alloys exhibit two closely related and unique properties: shape memory and superelasticity (also called pseudoelasticity). Shape memory refers to the ability of nitinol to undergo deformation at one temperature, then recover its original, undeformed shape upon heating above its "transformation temperature". Superelasticity occurs at a narrow temperature range just above its transformation temperature; in this case, no heating is necessary to cause the undeformed shape to recover, and the material exhibits enormous elasticity, some 10-30 times that of ordinary metal.
http://en.wikipedia.org/wiki/Nitinol
that sound more like ordinary bimetal, one shape when cold another when hot, afair an old VW used that to control theSectorOne wrote:Based on the fact that it can change shape when hot?
I wonder if you could have this in brake ducts, shape it so it lets in very little air, or re-directs air to another channel but when it starts to heat up, the hole takes it´s original shape and lets in more air to the brakes.
No idea just trying to figure out what sort of places could benefit from changing shape during a session.
An electrostatic fluid accelerator (EFA) is a device which pumps a fluid such as air without any moving parts. Instead of using rotating blades, as in a conventional fan, an EFA uses an electric field to propel electrically charged air molecules. Because air molecules are normally neutrally charged, the EFA has to create some charged molecules, or ions, first. Thus there are three basic steps in the fluid acceleration process: ionize air molecules, use those ions to push many more neutral molecules in a desired direction, and then recapture and neutralize the ions to eliminate any net charge.
http://en.wikipedia.org/wiki/Electrosta ... ccelerator
Yes, the device is commonly referred to as a "Gurney flap".SectorOne wrote: If you can do that with water, could you do it with air as well?
Could it be used to inhibit airflow from detaching from the bodywork in sharp angles?
I wasn´t thinking of wings necessarily but rather sharp angles of bodywork etc.riff_raff wrote:Yes, the device is commonly referred to as a "Gurney flap".SectorOne wrote: If you can do that with water, could you do it with air as well?
Hi! Just another question. How it is possible to do this also with air??? I mean water is deflected before the ballon touch the water itself for electrostatic reason exploiting the polarization of the water's molecula... Am I right?SectorOne wrote:I wasn´t thinking of wings necessarily but rather sharp angles of bodywork etc.riff_raff wrote:Yes, the device is commonly referred to as a "Gurney flap".SectorOne wrote: If you can do that with water, could you do it with air as well?
