Marine engine technology transfer to F1
shelly
shelly
136
2014 v6 turbo engine seem to share some technology with bigger marine engines (turbo compounding, turbo harvesting, exhaust scrubbers...) I was wondering how close this link can be - does somebody have some information about this?
twitter: @armchair_aero
Jersey Tom
Jersey Tom
Re: Marine engine technology transfer to F1
Don't know specifically. But technology transfer from consumer to motorsport certainly isn't uncommon.
autogyro
autogyro
I cannot see any reason to use a reciprocating internal combustion engine in any efficient modern marine propulsion unit.
shelly
shelly
136
I do not know much about marine propulsion, but I have seen that the turbo manufacturers (Borg wariner, honeywell etc) are also suppliere for big turbo marine piston engines, and that they offer for this field turbos that can either charge a battery or be assisted by an electric motor. This technology has not yet been applied to cars as far as I know.
Also, marine engine makers have developed (mainly for emissions control) exhaust management systems (like the exhaust scrubber) which have been applied to f1 cars from 2011 onwards, in the form of Helmoltz resonators and so on.
So it seems to me that a partnership between f1 engine makers and marine engine makers is a reasonable option, so that the f1 maker can get the knowledge quickly
Jersey Tom
Jersey Tom
autogyro wrote:I cannot see any reason to use a reciprocating internal combustion engine in any efficient modern marine propulsion unit.
Yet they're quite common...
langwadt
langwadt
what would you use instead?
flynfrog
His magic gear box its so good it doesn't need a motor
Pierce89
It doesn't even need a car. It has the "world's best seat" casted into the casing and little wheels built purely out of recovered energy.
riff_raff
riff_raff
The most efficient marine propulsion units in use are massive 2-stroke diesel engines. Every large ocean going tanker or container ship uses a recip engine with a direct drive propeller.
http://gcaptain.com/maritime/blog/wp-co ... sulzer.jpg
While some of the basic principles are the same between current F1 engines and large marine engines, such as turbocharging and turbocompounding, the implementation is far different.
A: Start with a large one!"
Holm86
250
shelly wrote:I do not know much about marine propulsion, but I have seen that the turbo manufacturers (Borg wariner, honeywell etc) are also suppliere for big turbo marine piston engines, and that they offer for this field turbos that can either charge a battery or be assisted by an electric motor. This technology has not yet been applied to cars as far as I know.
I really don't see what exhaust scrubbers and Helmholtz resonators has to do with each other? F1 engines doesn't use scrubbers.
AnthonyG
38
shelly wrote:This technology has not yet been applied to cars as far as I know.
Subaru or Mitsubishi(on of the two) has it on their new impreza/Evo.
autogyro
autogyro
I always see plenty of scrubbers in the paddock :wink: :wink: :wink:
