2014 transmissions
George77
George77
2014 transmissions
Is it true that the 2104 transmissions have a fixed ratios? I mean they are going to use the same rations in Monaco and Monza?
479
Re: 2014 transmissions
George77 wrote:Is it true that the 2104 transmissions have a fixed ratios? I mean they are going to use the same rations in Monaco and Monza?
Yes.
George77
George77
Why are they doing that to sport?
piast9
piast9
Do what?
George77
George77
Why the have 8 gears if they can not exploit all of them?
simieski
simieski
George77 wrote:Why the have 8 gears if they can not exploit all of them?
Some tracks they will use all, other tracks they won't. As I understand it the engines power band is over a much wider rev range in comparison to the peaky V8's, so getting gears bang on so that you always stay at the right point of the power curve isn't such an issue.
Thank you to God for making me an Atheist - Ricky Gervais.
piast9
piast9
In my opinion it doesn't do much difference. The fuel flow limited turbo engines have flat power curve at the top. BTW, this topic was discussed at length already http://www.f1technical.net/forum/viewto ... =4&t=15586
George77
George77
Understood, thanks.
Cold Fussion
Cold Fussion
93
This image from Cosworth demonstrates pretty well why the gearing wont be a huge issue.
autogyro
autogyro
Cold Fussion wrote:http://s29.postimg.org/cycq3y60l/image000003.jpg
It wont be with a conventional layshaft stepped ratio box thats for sure.
If they are content to accept that as the ultimate :wink:
rscsr
51
It would be nice if you could tell, where this is from.
Cold Fussion
Cold Fussion
93
http://www.f1technical.net/forum/viewto ... =4&t=17720
It's from racecar engineering magazine.
rscsr
51
no it's not. It is from "race engine technology". Issue #072. And I know it, because I uploaded that graph (and 2 others) on the intercooler thread: http://www.f1technical.net/forum/viewto ... 42#p478542
riff_raff
riff_raff
A lower rev limit, turbocharging, and KERS should lessen the impact of transmission gear ratios.
A: Start with a large one!"
strad
117
Really? And when it's not being assisted? I sure don't read it that way. I don't see it as a broad power band.
Sir Stirling Moss
