Ciro Pabón wrote:Oh, sure. If you extrapolate this thread assumption we can quickly conclude that an infinite power engine would have zero fuel usage, while a zero power engine would have infinite fuel consumption.
Simple: with infinite power, you could accelerate instantaneously and would arrive in zero time, having thus zero drag and zero rolling resistance.
Your speed would be infinite meaning that you wouldn't have any losses in acceleration: as the air surrounding the car will not be aware of the presence of the vehicle (it would spend zero time crossing the air volume over the track) you could affirm with confidence that drag would be zero.
It would be as if the car never passed through the atmosphere.
Of course, cornering would be a bit of an issue, but let's not become party poopers, will ya?
On the other hand, any engine delivering zero power would spend an infinite amount of gas, no matter how tiny its fuel usage, because you would be trying to arrive (but not succeeding, of course) in an infinite time.
In conclusion, small cars with small engines are killing the environment
That's why I drive a Hummer (well, my second car is a Cadillac Escalade, but I'm thinking of selling it and buying two Hummers: you can never save enough fuel these days).
Final consideration: everybody knows that hypermilers get their extraordinary fuel mileages by accelerating harder than the regular driver.
So, my recommendation for cars that are running low on fuel towards the end of the race is to push the throttle harder.
Jokes aside, everything being the same in terms of the car, the generation of power is directly proportional to the amount of fuel spent, dear friends.
Ciro, you sure opened a can of worms with that comment, and I'll argue with you just for fun.
Since there is a limited amount of fuel carried by the car, and that fuel mass has a theoretical limit of energy it can produce via combustion, the amount of power the engine can produce is also limited. In theory, an engine producing infinite power would need to combust some fuel, since a system with zero energy input will always have zero net output. On the other hand, an engine could conceivably combust fuel without producing any net output, which would result in an infinite BSFC rate.
