Carbon Rotor/Disk bobbin suppliers?
smokey1
smokey1
Hello.
Received a discarded F1 carbon rotor and titanium hat. Would like to find a UK supplier that would have the correct application brake bobbins for an F1 application. Does anyone know any UK based brake suppliers that would carry those items and/or is this such specialized application that teams have titanium bobbin's manufactured for their specific purpose? I called around the US, but no such luck.
If the disk/hat bobbin's are not a one-off type item, was hoping to find a UK supplier and purchase a set
Sure its a wall hanger/F1 piece of art, but wanted to accurately display the kit.
Jim
Austin,Texas
riff_raff
riff_raff
Re: Carbon Rotor/Disk bobbin suppliers?
You'll probably have to get your own hat bushings machined. Each titanium hat bushing will likely cost you $50 or more. Here are AP's guidelines for mounting CRC brake discs: http://www.apracing.com/drawings/CP2872_1000CD.pdf
If you want to be authentic, you'll also need to purchase a set of aircraft quality titanium or inconel bolts and locknuts. This will probably set you back around $20 per bolt or locknut.
Good luck to you.
A: Start with a large one!"
Ledon Racing
Ledon Racing
The bell you have there is from a 2009 Brawn GP car, I deal in used F1 parts http://stores.ebay.co.uk/Ledon-Racing-S ... 7675.l2563 and have some titanium brake bobbins available that will fit that bell (I've just checked as I also have one at the moment), the bobbins I have are from an earlier version of the Brawn car (a RA106 Honda), but the design hasn't changed much between the cars.
www.LedonRacing.com
Unique motorsport inspired gifts - F1 parts bought & sold
http://www.ledonracing.com
Monobloc
Monobloc
Can you re-post the pictures again?
