Ahh you mean like Mario perfected and taught to his kid. nothing new under the sun.I saw the concertina effect personally. Alonso varied his breaking on the apex visibly a few times, forcing Vettel either wide or to brake when he needn't.
F1fanatic usually posts the full radio transcript a few days after the GP. When they do, we'll know.SectorOne wrote: This might be all Rosberg´s radio transmissions but we can´t say for sure, i don´t know how much drivers really talk to to the team over the laps.
Where's a good profanity mod. when you need one?Juzh wrote:Vettel should shut ta fuq up. Alonso as well. He did close the door rather questionably sometimes.
The fuel usage graphic was shown in Malaysia and China, can't recall seeing it in Bahrain. I distinctly remember Hamilton using significantly less fuel than Rosberg thenPhil wrote:Perhaps we should be looking at earlier races to determin what kind of a fuel usage difference there was. If it is similar, then I see no reason to believe different fuel loads.
Or you can believe Alonso. He was in the car while we all watched. What part of that context was misleading for you?bhall II wrote:In terms of performance, and even considering the state of Alonso's tires and supposed stalling issues, I think the F14T and the RB10 were generally comparable enough that to call Alonso's aggressive tactics to hold position a "lost cause" is a bit misleading in context.
"We had two seconds deficit in pace, so if keeping him behind for 13 laps was good for the TV and our sponsors it is welcome, but we knew we would lose the position," Alonso said.
I would be amazed if that were the case, because that would be the very opposite of a level playing field. We know that Lewis uses less fuel over a race, so fueling the two cars the same amount would inherently give Rosberg an advantage - that he has a lighter car towards the end.Phil wrote:Bob,beelsebob wrote:You are. That looks like a pretty accurate summation of what I'm proposing.
That's a really good question. I think one possible explanation is above. Rosberg tends to get the "you're bingo fuel" warning in races he's leading - it could very well be that he puts his boot in to make sure he's ahead of DRS.So why does Rosberg suck so much at keeping below his fuel usage Delta that he is warned almost every race to get his stompers off the pedal?
My suspicion is that the difference between Hamilton pushing and not pushing is that he tries to carry more speed through corners, and push the limits of the track, while the difference between Rosberg pushing and not pushing is that he tries to get his boot down on the accelerator earlier, and to brake later.
I'd be surprised if Hamilton is fueled less for a simple reason: Watching how Mercedes likes to manage these two drivers - identical engine maps, using overtake-button during the same time (when racing each other), even down to the strategy or data sharing - it all points to me that the team or management of Mercedes wants to give the two drivers a level playing field.
We don't need stuff like this, if you wanna report someone, then do so....but,to waste space in an already overflowing thread just to tattle on someone...I guess I must be getting old or something.mkable1370 wrote:Where's a good profanity mod. when you need one?Juzh wrote:Vettel should shut ta fuq up. Alonso as well. He did close the door rather questionably sometimes.
Yup. Seconded.Juzh wrote:Definitely power. Be it ice or ers deployment. That ferrari was making short work of merc powered stuff into stowe at times during the race.seahawk wrote:What could be the reason? Better traction or more power?
Mostly because the stewards thought both of them were running off the track far too much. Vettel actually ran off the track 3 times during the build up, and passing move.NathanOlder wrote:Does anyone know why nothing seemed to have been mentioned (I didnt hear anything on Sky or BBC) about the passing move Vettel put on Alonso, and the fact that his pass was done in Copse and he ran 4 wheels over the white line on the exit !?
I don't remember the battle blow by blow- did Alonso keep the position by running off the track at any time?Cam wrote:Perhaps because Alonso spent time himself with all 4 wheels off the track, in defense?
